Author Topic: 1981 VW Rabbit L Diesel (ND)  (Read 4044 times)
February 04, 2011, 06:55:59 pm
gtiguy1994
  • 67
« on: February 04, 2011, 06:55:59 pm »
Slate Gray, 4 speed MT 1.6D 233,444 mi
The good:
Body is in great shape. Only one spot of rust on the doors and it is not major at all.
Seats are in great shape. No tears.
New Glow plugs
New Headgasket
New injectors
Oil changed about 1500 mi ago
Block heater works well. Started at -12 deg.
Strut towers are 100% rust free. ( <3 ND DOT for using sand...not salt)
The Balloon tires have good tread. about 80% and would probably float on water:biggrin:
Parking brake works well
Heat and blower work well.
The grill is not broken or cracked except a headlight bezel that goes between the light and the grill on the P/S
I flushed the brake system last month.
The Bad: (nothing show stopping or major)
When it was awfully cold I pulled the D/S door handle completely off and then broke the little finger tab on the other side. The DS rear door doesnt open.
The headliner is missing
The carpet needs shampooed.
The parcel lid carpet needs glued down
It looks as if the PO bypassed the fan switch with manual switch.
The fuel cap may need replaced. I ran it over last time I fueled it:mad: It seals but the plastic is cracked.
The hood release cable is broken. I ran it through the grill for a outside pull.
I cant remember which CV needs replaced. but I can replace that.
Clock doesnt work.
windshield is cracked
Only reason I am selling, I find my caddy more appealing..although in rougher shape.
The wheels pictured VW Bottle caps are not for sale. I dont have them anymore.
This is the only spot of rust I noticed
$1500 firm.... picked up.
I can also trailer to MSP area for $500
or to Fargo ND for $250
Located in Minot, ND 58701
I would consider partial trades for coil-overs for my caddy, drop plates, ABA bottom end (complete and in running order) a MKI or MKII head in running order, or a full ABA engine swap.
possibly other stuff.
Its also come with a draw bar to flat tow behind a vehicle with a 2" ball. (notice the mounts on the front bumper.)
Quickest way to get a hold of me is txt or call
701.340.6011
-Josh
World Rally Championship!
