Author Topic: N/A inj pump on a turbo motor???  (Read 2814 times)
January 10, 2006, 05:51:12 am
Peter
  • 136
« on: January 10, 2006, 05:51:12 am »
until I get my turbo injection pump fixed ...can I run the 1986 turbo motor just useing a N/A inj pump..are there any issues that I have to be concerned of
Reply #1January 10, 2006, 07:20:39 am
  • 1156
    • Malone Tuning Ltd.
Re: N/A inj pump on a turbo motor???
« Reply #1 on: January 10, 2006, 07:20:39 am »
Quote from: "Peter"
What libbypapa said.. and I'm in the same situation, currently running a stock 1.6L NA pump on my TD with no issues.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #2January 10, 2006, 08:28:30 am
Peter
  • 136
« Reply #2 on: January 10, 2006, 08:28:30 am »
Mark if I understand correctly..is the turbo still being used with the N/A inj pump
Reply #3January 10, 2006, 09:17:50 am
  • 1156
« Reply #3 on: January 10, 2006, 09:17:50 am »
Yes the turbo still functions although the NA pump won't give you extra fuel under boost.
The Jetta Ecodiesel (1.6L) comes with a NA style pump and a turbo from the factory.. the turbo simply pushes more air into the engine for emissions purpose. It works fine, there are no issues with installing a NA pump on a TD. Just install and drive.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #4January 10, 2006, 04:15:21 pm
Justin
  • 455
« Reply #4 on: January 10, 2006, 04:15:21 pm »
I have heard that the boost aneroid is to keep the engine from smoking when you get into the throttle. but the other way makes sense and it was Just hearsay
www.archeryprostaffmi.com
Reply #5January 15, 2006, 07:25:36 am
Malacaco
  • 51
« Reply #5 on: January 15, 2006, 07:25:36 am »
i care about the smoke and fuel, and my car smokes badly, im desperate and dont know what to do. At the begining this "arenoid thing" was leaking fuel and the car was smokin a lot, then i fixed it, its not leaking anymore but the car still smokes a lot.........
1983 VW Golf MKI with swapped engine (1.6D to 1.6TD)
http://batracer.com/-1FrontPage.htm?1E.
--->check it out
