Author Topic: cold start stuck open....  (Read 4187 times)
January 26, 2011, 06:17:08 pm
Vohaul
  • 105
« on: January 26, 2011, 06:17:08 pm »
Hey all,
My cold start handle doesnt go back in...when i try it just "springs" back out....and even when i hold it closed..the idle doesnt decrease......where do i look to unstick it?...(the high idle gets a bit annoying..specially as my exhaust is a bit loose and rattles against a heatshield underneath somewhere at certian rpms:))
on a related note....do you use more fuel if you leave the cold start handle "on"?          oh, 93 jetta  1.9 TD AAZ
Thanks
Paul
Reply #1January 26, 2011, 06:53:31 pm
rabbitman
  • 2788
Re: cold start stuck open....
« Reply #1 on: January 26, 2011, 06:53:31 pm »
Look at the other end of the cable and see what's hanging up, you can poke the lever on the IP with a screwdriver to put it back.
Reply #2January 26, 2011, 08:54:35 pm
Vohaul
  • 105
« Reply #2 on: January 26, 2011, 08:54:35 pm »
ya, ill check that on the weekend......i think i might of bent it when i was changing out the glowplugs.........although it did it once before and it eventually became unstuck........
so does it use more fuel.....?
Reply #3January 26, 2011, 11:26:16 pm
rabbitman
  • 2788
« Reply #3 on: January 26, 2011, 11:26:16 pm »
It's idling higher so I'd say slightly, but of course that's only at idle, at driving RPM the knob has absolutely no effect on anything.
