Author Topic: injection pump cover leaking 98 AHU engine  (Read 6240 times)
January 24, 2011, 02:41:19 pm
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
« on: January 24, 2011, 02:41:19 pm »
the cover on the top of the injection pump of my 98 jetta is leaking. anyone ever taken the top off of one? do springs and things go flying  when the cover is removed? need to fix it ASAP. looks like there's 4 small allen heads holding it on. where can I get the seal?
thanks...
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #1January 24, 2011, 03:16:13 pm
Re: injection pump cover leaking 98 AHU engine
« Reply #1 on: January 24, 2011, 03:16:13 pm »
IIRC it is nearly identical to the 1.6 and 1.9 idi pumps in there.. with the lack of a throttle shaft going through it? I think i read this somewhere, somebody else needs to chime in though. lol
http://www.idparts.com/catalog/product_info.php?products_id=1784
Seems as though removing the pump cap/lid/cover will not cause you to loose any of your calibrations.
Reply #2January 24, 2011, 03:49:58 pm
ilikevwdiesel
  • 1202
« Reply #2 on: January 24, 2011, 03:49:58 pm »
thanks for that ID parts link bro. ;D I've spoken with the owner of that site he probably knows what's involved in changing that seal. I'm pretty sure that when you remove it you have to reinstall it in the exact same position that it was in before it's removed or it will affect the timing.
My Bio
Reply #3January 28, 2011, 01:09:57 am
snakemaster
  • 405
« Reply #3 on: January 28, 2011, 01:09:57 am »
dead easy to do just take out the 4 bolts lift off cover remove seal , fit new seal and when refiting the cover you got to get the botom of the E lever back on the control spool .
Reply #4January 28, 2011, 08:47:39 am
BigVWman
  • 332
« Reply #4 on: January 28, 2011, 08:47:39 am »
I don't believe its pump timing, but It does effect one of the settings though, maybe quantity adjustment iirc.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #5January 28, 2011, 10:50:41 am
  • 1739
« Reply #5 on: January 28, 2011, 10:50:41 am »
The only thing that will happen is if it's dirty and some crud falls inside. super easy
Reply #6January 28, 2011, 09:07:50 pm
Powered by Spearco
  • 1203
« Reply #6 on: January 28, 2011, 09:07:50 pm »
There is two tops to a TDI pump. the tippy top cover is easy to do. The next one down is just as easy but garrantied you'll need to do the "hammer mod " to readjust the quantity. You'll also need VagCom to do that as well. IIRC, taping to the drivers side increases and taping to the passengers side decreases quantity. Its been a while sence my last one, so it could be the other way.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #7January 29, 2011, 08:42:09 am
  • 1739
« Reply #7 on: January 29, 2011, 08:42:09 am »
Oh yeah, forgot about that. I tried doing that once when i was having some strange no power issues. I didn't notice a difference, even though it showed a small difference in fuel quantity in one of the measuring blocks.
