Author Topic: How to tell the back struts are toast...  (Read 7091 times)
January 22, 2011, 08:36:30 am
Patrick
  • 1034
« on: January 22, 2011, 08:36:30 am »
Went out and started the car after a gig last night about 1:30 am. Drove home with NO back suspension. Apparently my back struts have worn through and filled up with water.... Both are rock solid.  Glad it wasn't the fronts!  Guess what my project is THIS weekend.
Reply #1January 22, 2011, 08:39:49 am
Re: How to tell the back struts are toast...
« Reply #1 on: January 22, 2011, 08:39:49 am »
Been there, and it makes things worse when your fronts are worn too, then it just nose bounces after every bump..
thank god its a VW and you can change the rear shocks by hand. the springs are tame enough to not need a spring compressor..
hope that its a mk2.. you can change out both rear shocks in about 32 minutes..
Reply #2January 22, 2011, 08:44:31 am
Patrick
  • 1034
« Reply #2 on: January 22, 2011, 08:44:31 am »
Yeah, it's a mark 2 but it will take a LITTLE longer than that. Jetta, so you have to deal with the seat. Don't remember if I need my spring compressor or not, got cut down Passat springs...
Front ones don't take much longer when you have a spring compressor.
Reply #3January 22, 2011, 08:56:30 am
« Reply #3 on: January 22, 2011, 08:56:30 am »
oh yea, see, when ive taken suspension out, ive either had a stripped out jetta, or a golf/GTI to take it out of.
it might take you 37 minutes then.. lol.
Reply #4January 22, 2011, 05:58:55 pm
« Reply #4 on: January 22, 2011, 05:58:55 pm »
on my mk1 with bilstein sport struts/shocks and h and r springs i don't use a spring compressor
Reply #5January 22, 2011, 06:09:57 pm
« Reply #5 on: January 22, 2011, 06:09:57 pm »
Is there an easier way to get the top nut off? It would take me an hour just to undo the nut from the top of one. The bottom is easy and I know you don't need a spring compressor. I know I don't have a spring compressor and I have done the rear shocks before.
Reply #6January 22, 2011, 07:27:15 pm
lovinthedeez
  • 489
« Reply #6 on: January 22, 2011, 07:27:15 pm »
yup, it's called a ratcheting box wrench :P
« Last Edit: January 22, 2011, 10:19:00 pm by lovinthedeez »
Reply #7January 22, 2011, 10:22:49 pm
Grey_Smoke
  • 83
    fling wing for the win.
« Reply #7 on: January 22, 2011, 10:22:49 pm »
X2
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #8January 23, 2011, 07:00:07 am
« Reply #8 on: January 23, 2011, 07:00:07 am »
i reach through the spring and hold the strut shaft, then hit it with an impact
Reply #9January 23, 2011, 12:18:37 pm
Patrick
  • 1034
« Reply #9 on: January 23, 2011, 12:18:37 pm »
Normally an impact gun is all you need. I don't remember if I need the compressors on this car or not. It has passat springs in the back, minus a few coils to get the ride height close. I DO remember that full length passat springs require the compressor on this strut.
I've got a different spring in my wife's '91 golf, and I do know that one of the cars still needs a spring compressor. Just don't remember which one.
Mind isn't what it used to be, getting old I guess.
Reply #10January 23, 2011, 02:30:19 pm
« Reply #10 on: January 23, 2011, 02:30:19 pm »
Is there a way to get the spreaker shelf out? I don't see an impact fitting in the space provided.
Reply #11January 23, 2011, 02:35:25 pm
DCC
  • 184
« Reply #11 on: January 23, 2011, 02:35:25 pm »
Both sides have a series of small 10 mm nuts (3-4 in each side, maybe?). They are a bit tricky to undo, but once undone, you'll have plenty of space to work.
Reply #12January 23, 2011, 04:30:20 pm
« Reply #12 on: January 23, 2011, 04:30:20 pm »
you dont need an impact on the rear shocks.
only on the front struts. from my experiences atleast..
Reply #13January 23, 2011, 04:31:58 pm
« Reply #13 on: January 23, 2011, 04:31:58 pm »
im pretty sure there is room for one in a rabbit, u might have to flip the seat up
