Author Topic: White 1995 Passat Sedan AAZ 1.9TD w/ fresh motor & many new parts $2250 obo  (Read 4219 times)
January 18, 2011, 08:39:48 pm
Shaggy0911
  • 19
The motor now has just over 11,000kms since being completely rebuilt. Plenty of new parts were also replaced within the last 4500kms. Car runs strong and straight. Located in Toronto, Canada. Willing to travel somewhat to meet up. Car has a recent oil change with Rotella 0w40 w/ new Mann filter.
Car:
1995 White 4-door Passat 1.9L TD AAZ - cloth interior
Original paint with some clearcoat peeling on hood/front left fender/trunk lid
Was oil sprayed since new, minor surface rust in a very few places
Gets 40+mpg regularly
Puts out a strong 9-10 psi stock (have it turned up to 15lbs now with a turbonetics manual boost controller. It rarely sees that. I enjoy seeing the 40+ mpg it gets driving it economically)
Pioneer Mosfet CD deck
Lowered on Koni Red shocks w/ Eibach sportline springs w/ VR6 strut bearings/bushings
Magnaflow stainless steel exhaust w/ dual outlet muffler
Refurbished VR6 k-frame
Just replaced the steering rack with a good used VR6 rack w/ fresh fluid
New control arms
New control arm bushings
New front control arm bolts
New steering rack boots
New steering rack rubber mount
New tie rod ends
New ball joints
New Empi axles - both left and right
New rad fan temp switch
Fresh alignment
Like new all season Michelin tires
Momo steering wheel w/ adapter
MK4 shift knob & boot
Ignited electric boost gauge
1 1/4" Class 1 trailer hitch w/ wiring, drawbar, & 2" ball
Motor:
1.9L TD AAZ with just over 11,000kms
Completely rebuilt with all new german bearings, seals, etc.
Bored over with new pistons
TDI crank pulley upgrade
Clutched alternator pulley
Rebuilt cylinder head w/ all new valves
Rebuilt K24 turbo (4500 kms on it)
New injection pump resealed and tweaked by Giles of Performance Diesel
1.6td boost pin & spring
New glow plugs
New waterpump
New belts
New timing belt tensioner
New oil cap
New PCV valve
New clutch kit
New motor mounts (all 3)
New coolant reservoir cap
New air filter
Rebuilt Alternator
Almost all new hoses
Bad:
Front right/Rear left windows do not go down (have a good used front right window regulator w/ motor replacement)
About 5" worth of the headliner at the very front near the windshiled is seperating from the backing (does not affect visibility)
Slight oil leak at turbo oil drain line
A/C needs recharged - worked great before pulling motor for rebuild
Small crack at base of windshield on passenger side
Included in sale:
Folder of receipts of replaced parts, maintenance, etc.
New rear wheel bearing kits x 2
New rear drum spring kit x 2
Bentley Volume 2 (trans,susp,wheels,brakes etc.)
Haynes Manual
$2250 obo
Reply #1January 19, 2011, 03:04:38 am
Patrick
  • 1034
Looks like a good deal to me. Going to have to think about this.....  GOt a project car I'm supposed to be working on that never happens.
