General Information
Troubleshooting
Glow plug sensor/coolant sensor
Topic: Glow plug sensor/coolant sensor (Read 7366 times)
January 16, 2011, 10:15:05 pm
coke
January 16, 2011, 10:15:05 pm »
91 Jetta Diesel 1.6L NA
Is the sensor that feeds information to the glow plug relay the same part # as the one that sends the data to the instrument cluster for the gauge?
I can find a listing for gauge type, but not one for glow plug system. On my car, they are both black, 2 prong.
I ran into this issue 5 years ago or so but I can't remember what I found out.
January 17, 2011, 08:46:35 pm
Quantum TD
Re: Glow plug sensor/coolant sensor
January 17, 2011, 08:46:35 pm »
On the Rabbits, the sensor was the same for either, but was single-terminal.
On Jettas, there are 4 sensor colors AFAIK:
White= AC cutout on NA cars up to 1992 (2 terminal)
Brown= AC cutout for ECODiesel cars (4 terminal)
Blue= Fuel injection for digifant cars (2 terminal)
Black= Temp sensor for gauge, and prolly glow unit. (2 terminal)
If in doubt, try VagCat (which may be having problems currently), or Wagenstad.com
January 17, 2011, 08:49:29 pm
coke
January 17, 2011, 08:49:29 pm »
Ok. I'll see what I can find there. I know they're both black on my car, but I do believe to verify I plugged the gauge wire into the gp sensor and it was all off.
January 17, 2011, 09:06:58 pm
January 17, 2011, 09:06:58 pm »
Yuppers... when they are single units they are the same.. be they brass or black plastic.
Eventually (AAZ) both sensors were put in the same housing.
January 17, 2011, 09:08:24 pm
coke
January 17, 2011, 09:08:24 pm »
Never knew that. I found two black sensors. One listed Gauge and one not listed. Gauge sensor was like 8 bucks, the other was 17. Different part numbers, so I figure they had to have a different function.
January 17, 2011, 09:12:16 pm
January 17, 2011, 09:12:16 pm »
Hmmmm... different part numbers has me concerned that I may be full of it.
I'll check my ETKA... coulda swore they were the same.
EDIT: yeah, ETKA says the single pin black sensor is 049 919 501 a 0-125C temp sensor used for the coolant gauge, glow plug relay, and oil temp gauge/MFA (if equipped). It's got M10x1 threads, just like its brass predecessor.
The black sensor with two pins is a 171 959 481A 119C A/C cutoff switch. It's got M22x1.5 threads.
Last Edit: January 17, 2011, 09:19:30 pm by Vincent Waldon
January 17, 2011, 09:27:34 pm
coke
January 17, 2011, 09:27:34 pm »
Mine doesn't have threads at all. Its held in the plastic coolant flange with them o-rings and clips.
Two pins, black. I saw two different ones listed at another website, I can't even remember which one it was.
General Information
Troubleshooting
