Author Topic: What is going on here???? (turbo pump on an NA??)  (Read 2307 times)
December 22, 2010, 07:00:18 am
Naturally Aspirated
  • 27
« on: December 22, 2010, 07:00:18 am »
So an acquaintance showed me his 1.6NA 1991 jetta engine to help solve what pump he had and i came accross something i have not seen before. From the pictures below it looks as though a turbo pump with the aneroid (or whatever its called) is hooked up to the vaccum for the brake booster and some sort of blow off valve. Any ideas why this was done? He bought it this way and says it runs well. I was wondering the advantages
Reply #1December 22, 2010, 07:13:34 am
Re: What is going on here???? (turbo pump on an NA??)
« Reply #1 on: December 22, 2010, 07:13:34 am »
Merffy on here has the same deal. Only one I have seen, but it might be the alt. compensating pump that I have heard about. It does work similar to a TD pump only with vacuum. There is a pin with a ramp in it.
Reply #2December 22, 2010, 05:03:11 pm
« Reply #2 on: December 22, 2010, 05:03:11 pm »
it has vacuum hooked up to where the vent would be on a TD pump..
maybe as the engine revs go up, it sucks the diaphragm down, and increases fuel?
Reply #3December 22, 2010, 06:35:55 pm
« Reply #3 on: December 22, 2010, 06:35:55 pm »
yep. that is how merffs works. There is a spring and starwheel just like a TD as well. It is kinda different:D
Reply #4December 22, 2010, 07:05:55 pm
« Reply #4 on: December 22, 2010, 07:05:55 pm »
looks to be factory too?
