Author Topic: How do i install a Boost gauge?  (Read 3468 times)
January 07, 2006, 05:12:49 am
YoSono
  • 22
« on: January 07, 2006, 05:12:49 am »
It's my first turbo diesel, so i'm not sure how you go about installing things such as a boost gauge :)
For example, where and how does it plug in, also, is there any other gauges that would be useful?
cheers
lee.
Reply #1January 07, 2006, 07:40:00 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #1 on: January 07, 2006, 07:40:00 am »
is there a thin pipe that does from the inlet manafold to the top of the diesel pump(lda) if so cut it and fit a t piece to read boost pressure
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #2January 07, 2006, 07:41:09 am
chrissev
  • 694
Re: How do i install a Boost gauge?
« Reply #2 on: January 07, 2006, 07:41:09 am »
Quote from: "YoSono"
cheers
lee.
Hi:  you "T" the boost gauge line into the braided air line that goes from the turbo to the Injection pump across the top of the engine.  Then just run your boost line into the car and hook up your gauge to it.  Regarding other gauges, I've heard of some guys installing EGT gauges but that is usually only if you are running increased boost and fueling I think.
Reply #3January 07, 2006, 08:10:40 am
YoSono
  • 22
« Reply #3 on: January 07, 2006, 08:10:40 am »
cool, thanks for the reply guys, i have read yr instruction, and spotted the line i need to splice into :)
cheers
lee.
Reply #4January 07, 2006, 11:59:17 am
Malacaco
  • 51
« Reply #4 on: January 07, 2006, 11:59:17 am »
nice
1983 VW Golf MKI with swapped engine (1.6D to 1.6TD)
http://batracer.com/-1FrontPage.htm?1E.
--->check it out
