Author Topic: Advice on refitting injectors.  (Read 3224 times)
December 09, 2010, 11:28:02 am
DCC
  • 184
« on: December 09, 2010, 11:28:02 am »
Hi there.
A friend of mine has a set of GTD injectors that were cleaned, re-calibrated and work very nice. He actually dumped his idi engine in favour of a TDI swap, so I have this set of 4 refreshed injectors I would like to install, as mine are just so-so.
The thing is: how do you tighten the injectors? I don't want to break an injector boss. Any advice you could give me would be very appreciated!  :)
Reply #1December 09, 2010, 04:16:45 pm
Mark(The Miser)UK
  • 1557
Re: Advice on refitting injectors.
« Reply #1 on: December 09, 2010, 04:16:45 pm »
Use a 'T' bar and torque until the heat shield gives, then nip up to the point where greater resistance is felt.
Did he tell you what the number of the nozzles are and their break pressure?
Mark-The-Miser-UK
Reply #2December 09, 2010, 05:24:02 pm
Quantum TD
  • 1195
« Reply #2 on: December 09, 2010, 05:24:02 pm »
Or, just use a torque wrench set to 52lbs.  ::)
Reply #3December 09, 2010, 05:34:06 pm
« Reply #3 on: December 09, 2010, 05:34:06 pm »
Most importantly always go toward the head not away when torquing or breaking loose.
Reply #4December 10, 2010, 12:29:47 am
Mark(The Miser)UK
  • 1557
« Reply #4 on: December 10, 2010, 12:29:47 am »
Assuming he has one.
 Use a swivvel joint to remove incorrect leverage, if your socket set has one. I prefer to get to know the feel for my nuts ;D
Mark-The-Miser-UK
Reply #5December 10, 2010, 12:54:52 am
DCC
  • 184
« Reply #5 on: December 10, 2010, 12:54:52 am »
The guy brought the injectors to a Bosch workshop and they were cleaned, calibrated and tested. They used oem nozzles and set the break pressure to 155 bar (stock, iirc).
I have a T bar, and a torque wrench as well. I think I will use the T bar to install and tighten them initially and finish with the torque wrench. I also like to feel by hand when bolting things.  :)
Thanks for the advice!
Reply #6December 10, 2010, 09:08:46 am
Quantum TD
  • 1195
« Reply #6 on: December 10, 2010, 09:08:46 am »
I've seen these as cheap as $10 on sale. Not sure why anyone would work on anything without one on hand:
http://www.harborfreight.com/1-2-half-inch-drive-click-stop-torque-wrench-239.html
Reply #7December 10, 2010, 11:15:09 am
jseeley
  • 106
« Reply #7 on: December 10, 2010, 11:15:09 am »
Have this exact one; picked it up for $10 buck on  sale... I'm sure it's wildly inaccurate... but I have used install my injectors a few times... currently running chepo $25 dollar prothe injectors (gotta cut cost somewhere to afford the Giles pump)
I'll get my Bosch ones rebuilt someday...   ::)
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
Reply #8December 10, 2010, 03:04:07 pm
Mark(The Miser)UK
  • 1557
« Reply #8 on: December 10, 2010, 03:04:07 pm »
The most reliable are the simple torsion bar. The micrometer type are prone to lying, but you never know when.
I have honestly just checked out my Snap-On one for the first time:  that my former tenant gave me some years ago,  :o
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=8542&group_ID=964&store=snapon-store&dir=catalog
Now that was impressive.  ;D
He said his son had replaced it with a newer one...
Mark-The-Miser-UK
Reply #9December 10, 2010, 04:20:45 pm
Quantum TD
  • 1195
« Reply #9 on: December 10, 2010, 04:20:45 pm »
Yeah, but it's kinda hard to accurately read the needle when you're torquing a head gasket.
Reply #10December 10, 2010, 05:57:13 pm
Mark(The Miser)UK
  • 1557
« Reply #10 on: December 10, 2010, 05:57:13 pm »
I agree it takes a little practice, and not helped by the 2 scales; Newton-meters and Kg-years or something equally obscure.  ::)
Mark-The-Miser-UK
