Author Topic: Battery relocation ( Caddy ) Under The Bed  (Read 5205 times)
December 08, 2010, 03:27:39 pm
GEE-BEE
  • 1604
« on: December 08, 2010, 03:27:39 pm »
After looking for more room in the engine compart area I decided to do it another way !
Odyssey Battery for under the bed
Model ER40 : 9.8 Long x 3.8 Wide x 8.1 tall
Weight 27.5
1100  cca
I will be using there HDER40 battery mount and send it to a shop that will make a horizontial side load battery tray.
I will place it forward of the tire carrier, and plan on welding on a 316 s/s 12 X 12 X 3/16 thick plate for the support the battery tray.
found this shop :
http://www.speedpartz.com/foz_batterybox.htm
I will use a 2/0 cable from the battery to the remote terminal ( BMW E30 Model )
GB
« Last Edit: January 08, 2011, 05:30:54 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1December 09, 2010, 10:52:03 pm
mystery3
  • 774
Re: Battery relocation ( Caddy ) Under The Bed
« Reply #1 on: December 09, 2010, 10:52:03 pm »
I'm intrigued! What happened to the behind the seat idea? I think I'm still planning to go behind the passenger side seat with my redtop, if it will fit in a box?
Reply #2December 09, 2010, 11:34:34 pm
GEE-BEE
  • 1604
« Reply #2 on: December 09, 2010, 11:34:34 pm »
I have corrado seat's , no room back behind mine...
I going with a horizontal mount just in front of the spare tire carrier..
ground off probly a 1/2 lb of undercoat to have a clean weld for the plate
GB
« Last Edit: January 03, 2011, 08:03:48 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #3December 10, 2010, 06:40:46 pm
« Reply #3 on: December 10, 2010, 06:40:46 pm »
couldn't resist
« Last Edit: December 11, 2010, 02:37:26 pm by Trev0rbr »
Reply #4December 28, 2010, 08:07:18 pm
GEE-BEE
  • 1604
« Reply #4 on: December 28, 2010, 08:07:18 pm »
Note :Iam going with Speedpartz to make a piggyback model to hold two ER40 odyssey battery's
I sent him a vertical ER40 battery mount to copy...
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #5December 30, 2010, 02:09:39 pm
dennis
  • 311
« Reply #5 on: December 30, 2010, 02:09:39 pm »
What are you using for rear bumpers???
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #6December 30, 2010, 11:49:49 pm
GEE-BEE
  • 1604
« Reply #6 on: December 30, 2010, 11:49:49 pm »
Those are the South African Bumperette's
I switch back and forth when I need a to tow my zodiac or jetski trailer
Giles Pump OHC
MK1 JETTA DASH
