Author Topic: I want to lower 1"  (Read 8339 times)
Reply #15December 07, 2010, 08:43:29 pm
Re: I want to lower 1"
« Reply #15 on: December 07, 2010, 08:43:29 pm »
While still on the topic ;)
There is two that i am looking at from Race land, and they appear to have different looking springs.
Lowering Springs for VW Golf Jetta I Mk1 (Does not fit Cabriolet)
Golf I 1.6 GTi / 1.8 GTi / Jetta 1.6 GLi /1.8 GTi / 1.6D
Drop: 25mm F/R
Golf I / Jetta I 1.1 / 1.3 / 1.5 / 1.6 excluding GTi /GLi
Drop: 40mm F/R
The first one that seems more geared towards the GTI and GLI's is only an inch drop, but seems a far more aggressive coil. Why would this be? Wouldnt you want the 40mm drop to be the stiffer and not the 25mm drop?
$58 for a nearly stock ride height.. seems it may be the ticket.. I'll have to think about it lol
Reply #16December 09, 2010, 09:22:35 am
« Reply #16 on: December 09, 2010, 09:22:35 am »
if you cut coils, just remember that the spring rate gets stiffer with every coil you cut.. even part of a coil can change the ride firmness..
i would go with the -25mm springs, or a set of sport, stock ride height springs...
mk1s bottom out too much, what can we do to fix it besides leave our cars, stock, or lifted?
the more i think about it, the more i STILL want to lift my rabbit..
Reply #17December 09, 2010, 10:32:48 pm
mystery3
  • 774
« Reply #17 on: December 09, 2010, 10:32:48 pm »
Higher spring rates and firmer damping?
Reply #18December 10, 2010, 06:02:33 pm
rallydiesel
  • 1880
« Reply #18 on: December 10, 2010, 06:02:33 pm »
Cutting your springs will almost always result in a crappy bouncy ride for the reasons mentioned above. Might be ok if you went to stiffer shocks to deal with the now stiffer springs but on stock shocks it will suck and eventually blow the shocks out completely.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #19December 11, 2010, 06:35:53 pm
« Reply #19 on: December 11, 2010, 06:35:53 pm »
Lowered stance
Lowering device
All you need to eliminate a little wheel gap is 4 Short blocks. That will give you lowering without changing springs LOL
Posting a couple more in that for sale thread about my trip as well.
Reply #20December 11, 2010, 07:12:37 pm
« Reply #20 on: December 11, 2010, 07:12:37 pm »
hah niice
Got some parts on the way to lower me down :)
