Author Topic: boost drops off unexpectedly  (Read 2268 times)
November 26, 2010, 07:11:08 pm
wiener
  • 14
    smokin
« on: November 26, 2010, 07:11:08 pm »
Did some minor mods on my pump(fuel screw etc),disabled the governor added a fresh air intake,have pyrometer   and boost gauge.
the boost occasionally will hit 25lbs.(but often only 15 lbs.boost) and usually drops back to 10 lbs.
I have played with the waste gate and even disabled it with no positive results.
Do I need a bigger turbo? Am running a stock turbo on my 94 AAZ Jetta and planning to upgrade any suggestions as to replacement turbos? FMIC coming soon also.
« Last Edit: March 09, 2011, 02:36:19 pm by wiener »
Reply #1November 26, 2010, 10:04:07 pm
hairyuk
  • 4
Re: boost drops off unexpectedly
« Reply #1 on: November 26, 2010, 10:04:07 pm »
could be your wastegate
Reply #2November 27, 2010, 08:26:37 am
wiener
  • 14
    smokin
« Reply #2 on: November 27, 2010, 08:26:37 am »
 played with and disabled  wastegate and it didn't help
« Last Edit: November 28, 2010, 07:18:18 am by wiener »
Reply #3November 27, 2010, 10:04:09 am
« Reply #3 on: November 27, 2010, 10:04:09 am »
which turbo do you have?  kkk turbos are alot of sticky wastegate valve issues, could also be an exhaust manifold or intake leak
