General Information
Troubleshooting
Heater fan flow troubles
Topic: Heater fan flow troubles (Read 4444 times)
November 26, 2010, 06:26:04 pm
November 26, 2010, 06:26:04 pm »
New heater fan. Never worked well, but I thought it was the filter I retro fitted. I took that out and no change. The fan sounds like it is making mad wind, but nothing really comes out of the vents. I looked and hooked up the + and - correctly, but am wondering if I need to switch them? There just isn't much coming out of the vents anywhere. The difference between setting 1 and 4 on the fan really isn't much difference at all. I replaced the fan as I had the same problem with the old one
. There is no obstruction to the flow of air and the vents are not closed, but that is what it seems like.
What do I look for? Please help it is gettting cold
Round 2
November 26, 2010, 07:57:19 pm
85Jettaturbo
Re: Heater fan flow troubles
November 26, 2010, 07:57:19 pm »
You should be able to run the fan through it's speeds unbolted from the ductwork to verify the speed changes. If you can't visually and feel a difference in speed then it is still electrical.You didn't say how you confirmed there are no obstructions anywhere but without removing the entire dash and verifying, that still is a possibilty. I've had mice build many a nest in the duckwork and it plugs it all up. If you have AC the evaporater can get blinded over but you should be able to see that with the fan out.
November 26, 2010, 08:57:11 pm
Powered by Spearco
November 26, 2010, 08:57:11 pm »
You have a MK2 Jetta/Golf right. When was the last time you did a heater core, and if you did it, did you reseal the vent doors in the box. The foam on the doors falls off and basicly you have no controll of flow and just blows everywhere.
Does that sound like your problem?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
November 27, 2010, 10:44:36 am
November 27, 2010, 10:44:36 am »
I just did the entire airbox this summer. I had everything cleaned and there are no obstructions. I replaced all the foam(I had to take it out the 2nd time for that) resistor, a/c evaporator, heater core, and then when driving it here in September I replaced the fan as well. The switch, fan, and resistor are working. It changes from the defrost vents, to the vents, to the floor...
There is just no flow. I made a cabin air filter and used that for a while. I just took that out last night thinking the fan would pull better but there is no change.
Is there a possibility that the wires should be going the opposite way? Brown is with - and the red black one is with + right now, but it seems like that is the deal.
Is there anything else I should try?
Round 2
November 27, 2010, 09:09:26 pm
Powered by Spearco
November 27, 2010, 09:09:26 pm »
Maybe the fan is blowing the wrong way
and is blowing out the fresh air inlet under the hood
I know it sounds dumb, but its worth a check
'13 Golf R:. Tuned
'98 Puch G320
November 28, 2010, 09:23:29 am
November 28, 2010, 09:23:29 am »
That is what I was thinking, but I can feel a little blowing out of the vents sometimes. My cabin air filter was dirty as well on the correct side, so I don't know what to think. The fan is just working way TOO hard for the lack of air coming out of the vents.
Does one of the flaps I put foam on shut off the flow entirely if in the wrong position? That is what it seems like is going on. If so how do I fix it?
Round 2
November 28, 2010, 11:36:22 am
Dakotakid
November 28, 2010, 11:36:22 am »
PM'ed 12:37 mountain time with some ideas. Hope something helps.
November 28, 2010, 03:45:49 pm
November 28, 2010, 03:45:49 pm »
Thanks for the ideas Dakotakid. I think you may have something with the cage not turning with the fan. It is either that or the factory wired the motor backwards. I will try some stuff when I can and report back.
In the meantime, any and all suggestions welcomed:D
Round 2
November 28, 2010, 08:13:24 pm
Dakotakid
November 28, 2010, 08:13:24 pm »
Light a candle on the passenger floor...run the heater....and preheat the engine
Sorry, Lucas....I couldn't resist!
General Information
Troubleshooting
