Author Topic: 1.6 na not starting after timing belt change and head replaced  (Read 3669 times)
November 26, 2010, 03:21:00 pm
pyro7890
  • 47
« on: November 26, 2010, 03:21:00 pm »
i changed my timing belt after putting a rebuilt head on it and i go everything done and had it running. i drove it 14 miles to flush the coolant, got the old coolant flushed and put some g 12 in and i came back about a week later after i got it registered and it will not start. it seems that i am getting fuel i have some fuel at the injectors i took the injector line off and it was dribbling, i though it should have some decent pressure tho? the glowplugs are working also.
i did put bio diesel in the tank to i think maybe i gummed up the fuel lines but am unsure. no fuel flowing through the injector return lines tho. also a lot of white smoke out the exhaust
thanks for looking
Reply #1November 27, 2010, 07:29:30 am
pyro7890
  • 47
Re: 1.6 na not starting after timing belt change and head replaced
« Reply #1 on: November 27, 2010, 07:29:30 am »
turned out to be the pump was just not primed
