Author Topic: Common VW turbo inlet/outlet sizes?  (Read 9393 times)
November 24, 2010, 09:52:59 pm
  • 3468
    • McScrubbins Body Wash
« on: November 24, 2010, 09:52:59 pm »
What are the sizes (inlet and outlet) of the kkk 24, kkk 14 and a Garret T3?
Looking to order silicone couplers for said turbos.
thanks.
Reply #1November 25, 2010, 06:51:42 am
Re: Common VW turbo inlet/outlet sizes?
« Reply #1 on: November 25, 2010, 06:51:42 am »
K24 is around 2.5IIRC The inside is small but the coupler will need to go over it all. IIRC what I bought it 2.5. The T3 should be the same. K14 I have  no idea. That is just for the air cleaner to turbo. The Exhaust to downpipe is around 2" or so. The boost pressure out let ???
GB will know I am sure :D
Reply #2November 25, 2010, 07:56:30 am
rodpaslow
  • 670
« Reply #2 on: November 25, 2010, 07:56:30 am »
I know the outlet on a T3 is a bit smaller than 2", but I use a 2" coupler and seems to work fine.  I think the inlet is about the same.
Reply #3November 25, 2010, 08:47:52 am
Dakotakid
  • 1240
« Reply #3 on: November 25, 2010, 08:47:52 am »
KKK 24:
Inlet is 60 mm.
Outlet is 50 mm. (outside measurement)
Reply #4November 26, 2010, 10:06:29 am
arsenicpants
« Reply #4 on: November 26, 2010, 10:06:29 am »
k14 is 1.875 both in and out i think
in I know for sure
i'll check when i get home
Reply #5November 28, 2010, 09:50:08 am
AudiVWguy
« Reply #5 on: November 28, 2010, 09:50:08 am »
I started a thread called "Manifolds and turbos" , it has some helpful pictures. (good luck with the search function)
Cheers,
-JB
Reply #6November 28, 2010, 11:42:01 am
GEE-BEE
  • 1604
« Reply #6 on: November 28, 2010, 11:42:01 am »
Turbo Duct( turbo to Intake manifold )
T2/T3/K14/K24 :  46 MM TO 49 MM
KO3 1.50 TO 2.33
EBAY ITEM 220624177746
Turbo Inlet from Snorkel
KO3 1.85
T2/T3/K14/K14 2.33
Snorkel here MK1:ebay item 220679730082
MKII is in production..
I know , cause I make them...
GB
« Last Edit: November 28, 2010, 11:49:11 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #7November 28, 2010, 04:50:48 pm
RadoTD
  • 513
    Stage WTF
« Reply #7 on: November 28, 2010, 04:50:48 pm »
So K24 is on the 49mm side of that, K14 on the 46mm side... is it better to run a 2" or 1 7/8" on the K14? How stiff are the silicone couplers?
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #8November 28, 2010, 07:46:25 pm
GEE-BEE
  • 1604
« Reply #8 on: November 28, 2010, 07:46:25 pm »
Smaller is the turbo side, ( outlet) to the larger size  manifold inlet
They dont stretch as much as the epdm rubber..
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9November 29, 2010, 07:34:15 pm
arsenicpants
« Reply #9 on: November 29, 2010, 07:34:15 pm »
i'm running a 2" coupler on my k14, secured with a t-bolt clamp, and it's been fine pushing 18 lbs
Reply #10November 30, 2010, 07:28:09 pm
Thezorn
  • 381
« Reply #10 on: November 30, 2010, 07:28:09 pm »
X2, make sure you run good quality t-bolt clamps, not cheap ebay kit ones, I snapped 3/4's of the ones my kit came with so I had to go buy some good quality ones.
Compounded 93 AAZ
Reply #11December 01, 2010, 06:58:50 am
GEE-BEE
  • 1604
« Reply #11 on: December 01, 2010, 06:58:50 am »
I include 100% stainless steel lined clamps on all my products
The adjustment bolt is s/s also , all made in the USA and is aircraft quality
If you dont use a lined clamp , it will cut into the silicone....
GB
Giles Pump OHC
MK1 JETTA DASH
