Author Topic: Video of AAZ waterpump shaft wobble  (Read 2219 times)
November 21, 2010, 06:15:59 pm
Henchman
  • 183
« on: November 21, 2010, 06:15:59 pm »
Changed out my waterpump this weekend (along with lots of other stuff).  Just a quick video of the play/wobble in the shaft.  It only started leaking last week, but got worse everyday.  The impeller had walked about 1/4" off the shaft at this point.
http://www.youtube.com/watch?v=dn7ibX0lQGg
Ian
Reply #1November 21, 2010, 08:15:50 pm
GEE-BEE
  • 1604
Re: Video of AAZ waterpump shaft wobble
« Reply #1 on: November 21, 2010, 08:15:50 pm »
did you replace the inner only or a complete assy ( housing )
I hope you did the thermostat while there and fresh G12 plus ?
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2November 21, 2010, 11:54:11 pm
« Reply #2 on: November 21, 2010, 11:54:11 pm »
Wow, did it leak? I just changed my 2 year old water pump that wasn't quite that loose, I noticed it way early in the summer but didn't get a chance to replace it. It hardly got any worse after I fist noticed it.
Reply #3November 22, 2010, 04:30:52 am
Henchman
  • 183
« Reply #3 on: November 22, 2010, 04:30:52 am »
I replaced just the pump, not the housing.  I was going to create a complete assembly because I have many spare bodies and seal it up ouside the vehicle, but that is a lot more labour intensive.  Thermostat with 1/4 bypass install mid summer.  I always use omni-coolant in the vw.  I was surprise at how clean the inside of the pump was! No scum or deposits.  I always mix with distilled water, so maybe that makes a difference.
Oil on the other hand I always use spec.
Ian
GB
