Author Topic: looking for compression tester  (Read 2398 times)
November 19, 2010, 02:00:13 pm
  • 3468
    • McScrubbins Body Wash
« on: November 19, 2010, 02:00:13 pm »
Looking for a compression tester. Southern bc. Right next to the border to WA.
Reply #1November 19, 2010, 04:29:44 pm
Wayland
  • 364
Re: looking for compression tester
« Reply #1 on: November 19, 2010, 04:29:44 pm »
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #2November 19, 2010, 05:18:30 pm
  • 3468
« Reply #2 on: November 19, 2010, 05:18:30 pm »
Great thanks for finding that for me!
Reply #3November 19, 2010, 06:07:06 pm
Dakotakid
  • 1240
« Reply #3 on: November 19, 2010, 06:07:06 pm »
Wayland, would it be possible for you to post a picture of the tip of your end which you screw into the injector hole? In other words, the point at which the pressure enters the tester.
I just want to compare the tip of it to my Mac compression tester. There is a reason I want to see it if at all possible. The reason is that my Mac allows pressure to enter directly in the middle....leading me to think I should leave the old heat shield in the hole....even though the Bentley says to take heat shields out when using the official VW compression tester.
I tested my friend's engine the other day and leaving the heat shield in yielded about 50 lbs. more per hole.
Thank you.
Reply #4November 19, 2010, 06:30:29 pm
  • 3468
« Reply #4 on: November 19, 2010, 06:30:29 pm »
Well the shield will take up volume that would otherwise be compression loss.
Reply #5November 19, 2010, 07:48:27 pm
Wayland
  • 364
« Reply #5 on: November 19, 2010, 07:48:27 pm »
I'll get a pic as soon as I can. I think I left the heat shield in last time I used it. My tester has a sort of adapter sleeve thingy with two copper sealing washers. I think this is because it's designed to work with a multitude of different motors. This will all make more sense once I post a pic!
93 Dodge CTD Truck
Reply #6November 19, 2010, 08:05:08 pm
ffgb
  • 244
« Reply #6 on: November 19, 2010, 08:05:08 pm »
I had a problem with my car one time when that happened.  There was such a huge air pocket in the fuel line that I thought it the fuel line was full of fuel.  What I did was take the in and out banjo, look inside to see if there was fuel to the top of the fittings.  If there wasn't, I filled the IP with ATF because it was a little thicker.  Then I had a empty plastic bottle, filled it up with diesel, and ran a piece of fuel line with an inline filter to the in banjo, and ran a piece of fuel line from the out banjo to to the plastic bottle.  That way, if the car started and ran, I could better diagnose the problem, be it a fuel issue from the fuel filter back, or stuck vanes inside the IP.  Hope this helps!
