Author Topic: Questions about VNT turbos. Specifically gt1852v  (Read 10516 times)
November 13, 2010, 05:38:39 am
« on: November 13, 2010, 05:38:39 am »
Is this Garrett 1852v or the gt2052vb too much for the IDIs? From what I have heard I think it would be good, but I know nothing about turbos in general. I have found many and for the money maybe cheaper than the VNT 1749vb.
Here is one on ebay that isn't bad a price http://cgi.ebay.com/ebaymotors/VW-Volkswagen-T4-2-5-GT2052V-454192-0001-Turbocharger-_W0QQcmdZViewItemQQhashZitem588af6340dQQitemZ380288513037QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
and this one in UK http://cgi.ebay.com/MERCEDES-SPRINTER-VAN-2-2-OM611-TURBOCHARGER-GT1852V-/310251353211?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483c6bf47b
granted I would have to make a manifold*modify or adaptor*, downpipe, and oil lines again, but that isn't hard. I just need you guys that know the engines if this is a perfect fit or way too big or maybe as laggy as the k24 and t3 or whatever. I guess I am wanting more total power and the same kind spool I have now.
Reply #1November 13, 2010, 10:15:52 am
Re: Questions about VNT turbos. Specifically gt1852v
« Reply #1 on: November 13, 2010, 10:15:52 am »
i definitely like my 1749.. it spools low, and hard.. and they are easy to find. and no need for a manifold.
my personal preference tho..
Reply #2November 13, 2010, 10:21:33 am
« Reply #2 on: November 13, 2010, 10:21:33 am »
But there are different 1749 turbos. From what I gather the 1749vb is the one that most are using for more power, but upgrade that to a 17/22 on TDIs. This is the 1.6 IDI so I don't know what to think, hense me asking the "experts":D
Reply #3November 13, 2010, 10:37:51 am
« Reply #3 on: November 13, 2010, 10:37:51 am »
I would try to run no more than 30 but usually around 25-27psi...depending on how cool I can keep the air. My k24 is not laggy at all for me I don't think so if it is that good I would be happy. Do those fit the bill?
Reply #4November 13, 2010, 01:18:21 pm
MJF
  • 581
« Reply #4 on: November 13, 2010, 01:18:21 pm »
Boost is not that relevant measure, more important is how much air you can blow through engine. GT2052v from 2,5 V6 TDI Audi is good for 170hp@26psi, T4 gt2052v has slightly larger turbine side IIRC. Will spool quicker than stock T3/K24.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #5November 13, 2010, 07:20:31 pm
« Reply #5 on: November 13, 2010, 07:20:31 pm »
what turbo would you need for 200+HP
Reply #6November 14, 2010, 05:48:17 am
MJF
  • 581
« Reply #6 on: November 14, 2010, 05:48:17 am »
GT2359V or GT2260V for example if vnt is wanted.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #7November 14, 2010, 09:32:41 am
« Reply #7 on: November 14, 2010, 09:32:41 am »
How much power does the K24 support?
Thanks for the info looking forward to more and looking for those listed now:D
Reply #8November 14, 2010, 10:02:00 am
« Reply #8 on: November 14, 2010, 10:02:00 am »
if you are trying to make 200+ hp out of a 1.6, then why not take the 1.6 out, sell it, and drop in atleast an AAZ? i would go balls out and get the TDI engine.. 200 hp is EASY to obtain with a TDI.. you damn near have to be god to break 200 hp with a 1.6...
Reply #9November 14, 2010, 10:09:04 am
« Reply #9 on: November 14, 2010, 10:09:04 am »
I think 200 with a 1.6 will be fairly easy with the right turbo. I already have the giles pump.
Reply #10November 14, 2010, 10:20:17 am
« Reply #10 on: November 14, 2010, 10:20:17 am »
you still gotta keep the head on it tho. and 250 hp (for all rights and purposes) is maxed out on a 1.6D
ive been told, that to venture into the 200 hp range, you have to be very good, and have DEEP pockets..
head studs will keep the head clamped down, but the head will still flex with enough boost crammed under it..
and even if you do get 200 hp, its gonna be no fun as a daily driver.. your gonna need a HUGE turbo to flow that much air.
compounds maybe?
Reply #11November 14, 2010, 10:27:02 am
« Reply #11 on: November 14, 2010, 10:27:02 am »
Maybe I am wrong. Maybe not 200 but right there and reliable would work for me. Also as a daily and fun. I have put a ton into the car and am now kind of disappointed. An intercooler is the next move, but if the "big turbo lag" is what the car is now without the IC I could live with that. With the Giles pump and injectors, ported and polished head with undercut stainless valves I think with the addition of a VNT appropriately sized will be in the ball park. I also have a CIS manifold if needed, but will use my AKI 76 built mani with the VNT whenever I get to it...
Thanks MJF for those lists. I could find the GT 2359 reasonable, but the 2260 not at all. Also, would you know what cars these came from and if they had non VNT models with the same # to watch out for.
Reply #12November 14, 2010, 10:35:31 am
« Reply #12 on: November 14, 2010, 10:35:31 am »
for a FUN daily driver.. the vnt 17 works great. but it wont directly fit on a mk2/3 car without a special passenger side mount.. kinda like that super expensive mount Shortysclimbin was trying to sell.. i think he would have sold some had they been reasonable about the prices..
Reply #13November 18, 2010, 07:38:12 am
« Reply #13 on: November 18, 2010, 07:38:12 am »
On these turbos what is the spool like? And they are both for around 200 hp? I have fuel to spare...I turned the boost pin to the aggressive side that basically put it back to where Giles had it and it looked like the boost gauge couldn't keep up with how fast it was building with my kkk k24. It also turns into a heat pump since it isn't intercooled now. I put it all back :( I figure if I go VNT why settle for 140 or 150 or even the 176, might as well go big, but I daily this so it needs to spool as good as the K24 if possible. Or I probably will go with the 176 ish size :D
Reply #14November 18, 2010, 07:47:19 am
« Reply #14 on: November 18, 2010, 07:47:19 am »
The VNT17 on a 1.6 will boost nicely up into the high 20s easily with even moderate fueling.  Lag is minimal, giving some boost off idle, but not really spooling fully until 2000 rpms or so.
That sounds like heaven to me.  The T3 doesn't even start to spool at 2000 rpm's with my foot buried in it.
Gotsta find me one of them.  :)
