Author Topic: Short or tall injectors?  (Read 3646 times)
November 12, 2010, 02:26:58 pm
regcheeseman
  • 714
« on: November 12, 2010, 02:26:58 pm »
I've the choice of GTD or AAZ injectors - both sets need a service but which should I choose?
The AAZ ones may be 1Y ones from a NA 1.9 engine....
Reply #1November 12, 2010, 03:41:56 pm
arnold
Re: Short or tall injectors?
« Reply #1 on: November 12, 2010, 03:41:56 pm »
1y injectors are the same length as 1.6 injectors,aaz's are taller.
Are you going to do the new nozzles yourself then i would go by the gtd's.
Reply #2November 12, 2010, 05:09:11 pm
« Reply #2 on: November 12, 2010, 05:09:11 pm »
AAZ injectors will run a bit quieter but are much more expensive to get serviced.  Remember you need the hard lines that go with the injectors...
Reply #3November 13, 2010, 10:18:13 am
Mark(The Miser)UK
  • 1557
« Reply #3 on: November 13, 2010, 10:18:13 am »
Reg, there are some nozzles that presquirt, merely due to the tapered, or 'corded' nozzle tip.
Not sure of their numbers:
 Inspect some with an eyepiece from a microscope.
Note they only presquirt at low rpm...
The one on the left is slightly tapered
Mark-The-Miser-UK
Reply #4November 13, 2010, 03:03:56 pm
regcheeseman
  • 714
« Reply #4 on: November 13, 2010, 03:03:56 pm »
They were removed from a 1Y block and they are longer - not sure of your location, but could your info be US specific?  ???
Get the injectors that match your injection pump plunger
Aha....TDI injectors required then? I have a TDI head and plunger.
I have the lines, I was digging out a set of lines for my engine build and realised I had two types - it was then that I twigged I must have the two different injectors as well !
Mark - thanks for the info.
Reply #5November 14, 2010, 07:58:12 am
arnold
« Reply #5 on: November 14, 2010, 07:58:12 am »
Hmm i'm located in belgium (europe),here all the 1Y have short injectors(same lenght as the 1.6 engines),do they mention the pop pressure ?
Reply #6November 14, 2010, 08:53:19 am
« Reply #6 on: November 14, 2010, 08:53:19 am »
1y was never sold in the us
Reply #7November 14, 2010, 09:15:58 am
arnold
« Reply #7 on: November 14, 2010, 09:15:58 am »
Yes but didn't you got the 1.9 eco diesel (turbo'd with NA pump and injectors) ?
Reply #8November 14, 2010, 10:37:46 am
« Reply #8 on: November 14, 2010, 10:37:46 am »
only 1.9 the USA got was the TDI..
Reply #9November 14, 2010, 05:57:41 pm
Wayland
  • 364
« Reply #9 on: November 14, 2010, 05:57:41 pm »
Canada got the 1.9 in both Eco and true TD versions 93-97.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #10November 14, 2010, 06:06:02 pm
« Reply #10 on: November 14, 2010, 06:06:02 pm »
yeah we always get the ***ty end of the stick when it comes to foreign cars... it'd be nice if they would have sold cosworth escorts here, or many many other cars for that matter.
