Author Topic: For those owners with Oil Pan Guard's ( Oil Change drain plug)  (Read 2317 times)
November 08, 2010, 08:14:14 pm
GEE-BEE
  • 1604
« on: November 08, 2010, 08:14:14 pm »
Installed before the Oil Pan Guard
Optional  nipple to slide on hose for remote drain use...
http://www.quickoildrainvalve.com
Watch out it's 22.95 !   ::)
F106 or F106 N , 25.95 with nipple
Gee-Bee  :-*
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1November 09, 2010, 09:50:15 am
Re: For those owners with Oil Pan Guard's ( Oil Change drain plug)
« Reply #1 on: November 09, 2010, 09:50:15 am »
be careful, rocks, sticks, road debrits anything like that.. can open the valve.. ive seen more engines than i care to,  blow up from those stupid friggen valves.. be out offroading, and then out of nowhere, your engine starts knocking.. was not impressed.. when i rebuilt his engine i took that valve out of the oil pan and threw it as far as i could..
this is just my $.02,
but then again, not all of you guys drive your vehicles like we do, in the places that we do..
i value the bearings in my engine.. it doesnt bother me to take 22 seconds to twist the drain plug out with a wrench..
and then another 22 seconds to put it back in and tighten it down.
i could see how these valves would be GREAT if you were a fleet mechanic for over 100 cars, and did multiple oil changes every day..
ive also seen things come up, whammy the oil pan, and break that valve right off..
« Last Edit: November 09, 2010, 10:04:55 am by R.O.R-2.0 »
Reply #2November 09, 2010, 01:53:14 pm
GEE-BEE
  • 1604
« Reply #2 on: November 09, 2010, 01:53:14 pm »
Again , I have the huge barbeque grill on the bottom so this make's it easier to drain....
Nothing can get close to the pan...
want a pic?
[email protected]
1.9 aaz , lowered 2.25 with Neuspeed sway bar's
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #3November 09, 2010, 06:33:31 pm
« Reply #3 on: November 09, 2010, 06:33:31 pm »
I would just drill a hole in the oil pan guard.
Reply #4November 09, 2010, 09:32:52 pm
Vangruver
  • 162
« Reply #4 on: November 09, 2010, 09:32:52 pm »
I've always wanted to use an Oil extractor like this.
Top that with a centrifuge oil filter, and you'd never have to worry about oil drain pans ever again.
