Author Topic: wanted BOOST PIN  (Read 5067 times)
November 07, 2010, 08:34:07 pm
gribur
  • 84
wanted BOOST PIN
« on: November 07, 2010, 08:34:07 pm »
i am looking for a boost pin as an upgrade for my AAZ.  I believe they are from the 1.6 or some model of rover.
Reply #1November 07, 2010, 08:50:54 pm
Syncroincity
  • 727
Re: wanted BOOST PIN
« Reply #1 on: November 07, 2010, 08:50:54 pm »
The Rover pin is the real hot-rod... I had one but sold it a while ago. I still have a new set of KermaTDI AAZ injection nozzles, bigger than stock. Combining the pin and nozzles with bumped-up pop pressure makes the AAZ wake up.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #2November 07, 2010, 09:36:48 pm
gribur
  • 84
« Reply #2 on: November 07, 2010, 09:36:48 pm »
what rover does it come out of?  is there any way to buy one from the dealer?  what about vw wonder if dealer can get the 1.6 pin?
Reply #3November 08, 2010, 03:19:17 am
Patrick
  • 1034
« Reply #3 on: November 08, 2010, 03:19:17 am »
Should be a few in the local boneyards.....
Reply #4November 08, 2010, 05:16:59 am
« Reply #4 on: November 08, 2010, 05:16:59 am »
410 had one for me on here.
Reply #5November 08, 2010, 08:45:40 am
410
  • 581
« Reply #5 on: November 08, 2010, 08:45:40 am »
I still have some boost pins.  It depends what you want though.  If you're careful you can grind your aaz pin to give you more on boost fueling.
Reply #6November 08, 2010, 06:32:49 pm
Syncroincity
  • 727
« Reply #6 on: November 08, 2010, 06:32:49 pm »
I found a picture...The Rover pin is shaped sort of like a bell; wide at the bottom for about a 1/4" lip and then tapers in a linear fashion... it's nothing exotic, simply a linear diminishing diameter. If you have a drill press, you could probably chuck a stock pin and turn it on slow speed, and grind it down with a dremel, or take this picture to a machine shop.
JC McCavitt
'98 Jetta Wolfie
Reply #7November 09, 2010, 08:38:41 am
blackdogvan
  • 574
« Reply #7 on: November 09, 2010, 08:38:41 am »
The spring rate is pretty imortant too, AAZ spring is too weak & vomits fuel.
1991 Vanagon 1.9 mTDI
Reply #8November 09, 2010, 05:48:14 pm
mr.woods
  • 67
« Reply #8 on: November 09, 2010, 05:48:14 pm »
What are you looking to get for the injectors?
1.9 AAZ backed by a toyota tranny and dual cases, going into a rock crawler
Reply #9November 09, 2010, 09:12:52 pm
Syncroincity
  • 727
« Reply #9 on: November 09, 2010, 09:12:52 pm »
PM'd you.
JC McCavitt
'98 Jetta Wolfie
Reply #10November 10, 2010, 04:24:02 am
410
  • 581
« Reply #10 on: November 10, 2010, 04:24:02 am »
This is what I have.  1.6 pin on the left and my homemade pin on the right.
