Author Topic: Just curious about smoke.and turbos....:)  (Read 3859 times)
November 04, 2010, 10:10:49 pm
Vohaul
  • 105
« on: November 04, 2010, 10:10:49 pm »
on an aaz engine....all stock (ie no advance timing, extra boost / fuel etc) how much smoke is normal??
ive just always been curious...as mine smokes a small bit on full pedal when at higher rpms....
and on a related note..ive never driven another diesel other than my aaz.....turbo or non turbo.....how would you tell if theres a turbo failure..(major difference in power?)
im just curious as mine seems to have lots of get up and go, but only on higher rpms or when floored....
cheers
Paul
Reply #1November 05, 2010, 04:22:21 am
Henchman
  • 183
Re: Just curious about smoke.and turbos....:)
« Reply #1 on: November 05, 2010, 04:22:21 am »
That amount of smoke sounds normal to me.  As for the turbo failure, I believe the biggest indicator is burning oil, so blue smoke.
Ian
Reply #2November 05, 2010, 04:52:00 am
maxfax
  • 2126
« Reply #2 on: November 05, 2010, 04:52:00 am »
The most typical turbo failure is the oil seals, which as mentioned causes blue smoke and oil consumption.. Sometimes ALOT of smoke!!   Another sign would be excessive noise..  Kind of a whining.. Can be bad enough to sound like a siren.. And finally would be a *significant* loss of power when it just plain locks up (and possibly a tad more black smoke although VW uses a boos enrichment on the pump so the smoke is less likely)
