Author Topic: Transmission Rebuild?  (Read 15589 times)
Reply #30November 04, 2010, 08:59:55 am
smutts
  • 720
    ClackClackClackClackClack
Re: Transmission Rebuild?
« Reply #30 on: November 04, 2010, 08:59:55 am »
If you are doing surgery on the gearbox, BOLT KIT THE CROWNWHEEL! The suicide rivets will be SO disappointed if you do. ::)
My 1989 4T grenaded as a result of a rivet saying "Hi There!"
Reply #31November 04, 2010, 09:43:09 pm
« Reply #31 on: November 04, 2010, 09:43:09 pm »
I have an ACN with a .71 5th and it's great on flat highway with my 1.6td. That's another nice thing about building your own or having a vw specialist build your trans as opposed to your local tranny shop. You can have it custom geared to your engine and driving habits. I used to have a 4S trans, which is one of the oem diesel trans' and it absolutely sucked on the highway. Buzzing at 3000 rpm @ 100 km/h and the egt's were nearly maxing out.
ACN came with a .75 fifth gear.. so you dropped a whole 40? rpms on that upgrade?
Reply #32November 04, 2010, 09:44:50 pm
« Reply #32 on: November 04, 2010, 09:44:50 pm »
If you need a new ring and pinon for your build ?
90 % percent are shot
Do install a arp bolt kit in your build
I have a new set 3.67
GB
see i dont know if the 3.67 R&P is geared higher (as in go faster) or geared lower (as in 70mph is 3K RPM  ;) )  than mine already (
what trans is in your car?
3.67 is the tallest gears you can get for a VW 020..
Reply #33November 04, 2010, 11:41:19 pm
GEE-BEE
  • 1604
« Reply #33 on: November 04, 2010, 11:41:19 pm »
CHD 3.67 WITH .71
16V Internals
12 Pt ARP complete  in /out
Peloquinn
Iwas searching for a 3.42 Ring and Pinon
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #34November 05, 2010, 12:52:11 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #34 on: November 05, 2010, 12:52:11 am »
AMEN to that. My old CHD started making diff bearing noises, so I got a shop to do the diff bearings for me. I asked them to do the rign gear rivets at the same time, but they didnt do it ( they said they didn't figure out what size they needed, 12 or 14mm).
3 weeks later, one of the rivets sheared off and went through the casing. luckily the shop that did the 'rebuild' for me met me half way and supplied me with all the bits to do a 02A cable shift conversion for cheap.
'91 Golf Cabrio 1.9TD
Reply #35November 05, 2010, 09:18:09 am
rallydiesel
  • 1880
« Reply #35 on: November 05, 2010, 09:18:09 am »
The original fifth was toast. I wouldn't have taken the time otherwise.  ;D
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #36November 05, 2010, 09:31:12 am
« Reply #36 on: November 05, 2010, 09:31:12 am »
that was the only logical answer i could find too.. dunno why someone would swap put a great 5th gear, for another equally great 5th gear, just for 40 less rpms..   ;)
Reply #37November 05, 2010, 11:01:55 am
GEE-BEE
  • 1604
« Reply #37 on: November 05, 2010, 11:01:55 am »
I have a set of 90 mm axles also with less than 1k miles, 100.00 shipped
if you need them...
MK1 type
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #38November 05, 2010, 11:32:28 am
« Reply #38 on: November 05, 2010, 11:32:28 am »
i have some 90mm flanges, if you want one, i will sell you one.. way cheaper than 100 bucks too. pm me if you feel like it. 100 bucks for 2 flanges is kinda expensive if you ask me. and i dont run 90mm flanges anymore. i like 100s better, even tho 90's are easier to take the axle off of..
*EDIT*
-i have both early and late style flanges. the ones for the conical washers, and the ones without..
but if you got an 83 car, it probably takes the non-conical washer kind..
either way.. got both kinds.-
« Last Edit: November 05, 2010, 03:37:37 pm by R.O.R-2.0 »
Reply #39November 05, 2010, 03:45:59 pm
« Reply #39 on: November 05, 2010, 03:45:59 pm »
VWTRANSAXLES.COM
OR NEW BLACKFORESTINDUSTRIES
I sent vw transaxles a CHD,it had bad Ring & pinon gear and a peloquin
He did 16V internal's and a FF final 3.67/ .71
He sent the case back to me for powdercoating and I returned it back to him with a complete set of ARP external bolt's ( 12 PT Stainless Steel)
OHC was 1089.00
Bolt kit 105.00
Peloquin 785.00
Powder Coating satin black 85.00
I was tring to find a 3.42 Ring and pinon , But no luck...
Gee-Bee
16v internals and mk3 internals are identical, minus the gear layout.. and im 99% positive you cant mix and match r&p... or fifth gear...
16v/mk3 trannies have a BIGGER input shaft, and pinion shaft, and as a result, every shaft in the trans is bigger than a regular old 8v unit..
i dont see how its possible to have a 16v gear set, with an 8v 5th gear, and a 8v ring and pinion, unless it was a mk3 3.67 unit..
in an 8v trans, the input shaft, and the pinion shaft are both SMALLER.. 8v and 16v 5th gears have different I.D.
this seems like a set of 159mm rods with 16v pistons properly pressed on..
(i could be wrong)
Reply #40November 06, 2010, 08:00:15 am
GEE-BEE
  • 1604
« Reply #40 on: November 06, 2010, 08:00:15 am »
it is a late chd MKIII trans
100 mm inners and 90 mm outers with new axles, No more wheel spin, perfect
shift's like a dream
I also installed lift strut's for the hood and a neupeed sway bar with all new parts
Solid driving
Here is what i have but no longer need
100 mm outer joints , new pair
90 mm inners attached to axles with less than 1 K miles
100.00 shipped
Giles Pump OHC
MK1 JETTA DASH
Reply #41November 06, 2010, 11:13:53 am
« Reply #41 on: November 06, 2010, 11:13:53 am »
pfft, i take that back GeeBee, that is a FAIRLY SMOKIN DEAL. $100 for 2 axles and the flanges..
Reply #42November 06, 2010, 07:18:21 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #42 on: November 06, 2010, 07:18:21 pm »
Im not gonna buy anything until i rebuild that trans. (that is when i get the money and call some people for prices) Long process  :-[
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #43November 06, 2010, 07:40:37 pm
rallydiesel
  • 1880
« Reply #43 on: November 06, 2010, 07:40:37 pm »
All of Gee Bee's posts MUST contain dollar amounts :D. Doesn't mean you have to buy it.
Reply #44November 08, 2010, 01:07:34 pm
« Reply #44 on: November 08, 2010, 01:07:34 pm »
 :D this is pretty funny, hope you dont take offense to it GeeBee..
