Author Topic: I was looking for VNT and found this  (Read 4644 times)
November 01, 2010, 07:26:58 am
« on: November 01, 2010, 07:26:58 am »
Someone might like the vnt 15 here.
http://forums.vwvortex.com/showthread.php?5070779-FS-Parting-out-TDI-ALH-Engine
I looked closer and to me it doesn't seem like bad pricing on most all the stuff. Not mine, but not enough $$$ for me to buy :D
Reply #1November 02, 2010, 02:01:19 pm
rodpaslow
  • 670
Re: I was looking for VNT and found this
« Reply #1 on: November 02, 2010, 02:01:19 pm »
Sold.
I have one question as I will need to re-clock the cold side.  Will it work turned up towards the top of the engine? I've seen posts to change it (doesn't look that difficult), but I'm wondering if the cold side will hit the block (outlet) or is the outlet away from the engine when turned?
Thanks for posting this theman53!
Reply #2November 02, 2010, 02:54:33 pm
« Reply #2 on: November 02, 2010, 02:54:33 pm »
why does everyone think that VNTs are almost impossible to clock? its just a turbo.. just re-clock it.. it doesnt take a degree in rocket science to re-clock a turbo.
Reply #3November 02, 2010, 04:22:09 pm
« Reply #3 on: November 02, 2010, 04:22:09 pm »
Glad I could help...now someone owes me a cheap 17vb if you see it.
How about the TDI block and pieces. That looked like good stuff too.
Reply #4November 04, 2010, 11:39:51 am
« Reply #4 on: November 04, 2010, 11:39:51 am »
17vb is gonna be hard to find. arent those the euro ones? and arent all the integral units 17v and 17va units?
Reply #5November 04, 2010, 04:34:52 pm
CdnVWJunkie
  • 309
« Reply #5 on: November 04, 2010, 04:34:52 pm »
I have a 17va and it isn't integral.  Came from a 2.0L BHW.
Reply #6November 04, 2010, 06:17:55 pm
« Reply #6 on: November 04, 2010, 06:17:55 pm »
The 17vb came off of the BEW and some ALH engine codes from what I have found.
The VNT 15 was discontinued in name only and then called the GT1749V the VA isn't much bigger at all. The true 17 is the 17vb and that is what I am after...or a 17/22 hybrid.
This is what I got for the info:
Garrett designated turbos           intake Bore                     Exhaust Bore
GT 1749 V (GT15)                             1.326"                                 1.441"
GT 1749 VA                                        1.390"                                 1.467"
GT 1749 VB (THE"17)                      1.459"                                 1.505"
GT 2052 V(The "20)                          1.550***                              1.550***
GT 2252 V                                           1.550 ***                                  ***
GT 2356                                              1. 587                                   1.605
GT 2552 V                                 to many sizes to list               1.550 to 1.700
