Author Topic: What rear wheel drive VW's will a AAZ bolt into - transmission wise  (Read 13790 times)
October 31, 2010, 02:20:16 pm
homerj1
  • 433
A bit confusing, sorry,
Are there any rear wheel drive VW's transmissions that I can bolt my AAZ to.  Basically 'm thinking of putting my AAZ into another car  ( a Vauxhall) and was wondering if there was a vw rear wheel drive trans -- ie Dasher, Fox  that the AAZ would bolt to.
And then, fitting-wise - I would just to mount the eng trans in the car and play with the drive shaft.
Aivars
Reply #1October 31, 2010, 02:34:25 pm
truckinwagen
  • 1895
Re: What rear wheel drive VW's will a AAZ bolt into - transmission wise
« Reply #1 on: October 31, 2010, 02:34:25 pm »
both the dasher and fox were front wheel drive, even though they mount the motor longitudinally.
there are however, plenty of transmissions from other cars(GM, Toyota, etc..) that will bolt up with a little work and an adapter plate/machining of the flywheel.
-Owen
83 Opel Kadett Diesel
Reply #2October 31, 2010, 07:03:44 pm
« Reply #2 on: October 31, 2010, 07:03:44 pm »
ive never heard of/seen a rear wheel drive VW since the Beetles..
Reply #3October 31, 2010, 08:21:41 pm
« Reply #3 on: October 31, 2010, 08:21:41 pm »
vanagon... passat syncro... quantium syncro... golf ralley... golf offroad thing... the 49 vw motorsport golf 16v/g60s they built.. but honestly.. everything is 4wd except some vanagons..
Reply #4October 31, 2010, 08:24:43 pm
truckinwagen
  • 1895
« Reply #4 on: October 31, 2010, 08:24:43 pm »
and the RWD vanagons were rear engined, there were no RWD VW's that were front engined(that I know of)
-Owen
Reply #5November 02, 2010, 01:15:04 pm
« Reply #5 on: November 02, 2010, 01:15:04 pm »
-Owen
this is what i was getting at with my previous post..
Reply #6November 04, 2010, 10:31:08 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #6 on: November 04, 2010, 10:31:08 pm »
I think there has never been a front engined, rear drive vw, apart from the crafter (which is based on the merc sprinter anyway) and if you want to get creative, the forthcoming Amarok (which ofcourse will have 4wd).
If you're looking for suitable gearboxes - i would start with the one that came with the car you want to bless with the aaz, or look at some volvo, merc or toyota gearboxes.
'91 Golf Cabrio 1.9TD
Reply #7November 04, 2010, 11:32:52 pm
mystery3
  • 774
« Reply #7 on: November 04, 2010, 11:32:52 pm »
What about an early awd passat?
Reply #8November 05, 2010, 09:35:02 am
« Reply #8 on: November 05, 2010, 09:35:02 am »
take an audi 5000 quattro and simply remove the front axles, then hit the 2 diff locks and go for it..
(wont work without a lockable center diff)
LMFAO..
Reply #9November 06, 2010, 07:15:02 am
« Reply #9 on: November 06, 2010, 07:15:02 am »
maybe a 924 or something, they make kits to put water cooled engines in beetles too
Reply #10November 06, 2010, 09:50:51 am
MJF
  • 581
« Reply #10 on: November 06, 2010, 09:50:51 am »
Dunno if my quattro center lock is worn or something, but it didnīt hold when I tried to run it RWD. It kept kicking it off, did not sound too healthy... Better would be welding center diff solid, seen several times.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #11November 06, 2010, 10:10:52 am
mystery3
  • 774
« Reply #11 on: November 06, 2010, 10:10:52 am »
924/928/944's can be had pretty cheap around here, especially non-runners. When people find out how much a rebuild costs they frequently sell 'em cheap!
Reply #12November 12, 2010, 07:38:06 pm
blackdogvan
  • 574
« Reply #12 on: November 12, 2010, 07:38:06 pm »
Has no one mentioned the volvo trans in this thread yet? All the 240 diesels were D24's right? I'm pretty sure my friend's AAB (eurovan 2.4) Isuzu trucks volvo 4spd plus OD doesn't use an adapter plate.
1991 Vanagon 1.9 mTDI
Reply #13November 12, 2010, 11:41:50 pm
MJF
  • 581
« Reply #13 on: November 12, 2010, 11:41:50 pm »
4cyl has different bellhousing bolt pattern than 5&6cyl engines.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #14November 14, 2010, 09:46:09 am
« Reply #14 on: November 14, 2010, 09:46:09 am »
I looked at one at a dealership in Mexico about a month ago, I took pictures too. Its a neat looking truck and seems comfortable but I'm not convinced VW can build a pickup truck that doesn't fall apart after any abuse. It's expensive too and seems a little underpowered with a VW Golf engine powering such a big vehicle. I have a hard time believing they will sell well anywhere Toyotas are offered, especially where the 4WD diesel ones are available. IDK, I didn't drive one though maybe they are nice, the ones I saw were TDIs with 6 speed manuals.
Anyway, Suzuki Samurai/Sidekick are a fairly popular vehicle for VW diesel conversions and a few companies manufacture kits to adapt the engine to these vehicles and to some Toyota pick up transmissions (intended as an upgrade for the Suzukis). Search for this on google, there is a lot of information available on what it takes to do this conversion.
« Last Edit: November 14, 2010, 09:47:43 am by bajacalal »
