Author Topic: head swap  (Read 4945 times)
October 29, 2010, 02:13:38 pm
turborabbit
  • 41
head swap
« on: October 29, 2010, 02:13:38 pm »
Hey, gurus, can I put a 1.6 normally asspirated head on my spare 1.6 turbo block? With a turbo on it? This turbo is sluggish-I can get it rebuilt for around 250 usd or should I try aftermarket-I'm not interested in power as much as efficiency and economy-thanks-warren :)
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
Reply #1October 29, 2010, 07:31:01 pm
maxfax
  • 2126
Re: head swap
« Reply #1 on: October 29, 2010, 07:31:01 pm »
You should be fine in doing that..  Just as long as the NA head you have is the right one for the block.. Since you have a TD block it'll have the 12mm head bolts (early heads had 11mm). There are also 2 different blocks pending on whether you have hydraulic lifters or mechanical lifters..  The heads can be swapped to either block with some modification..
AS far as the turbo, if you decide to source it aftermarket do some research on your source..  SOme of the cheapo ones available are just that CHEAP...
Reply #2October 30, 2010, 08:22:42 am
turborabbit
  • 41
Re: head swap
« Reply #2 on: October 30, 2010, 08:22:42 am »
Is the Garrett a good rebuild? I see others talking about some exotics, but I think they are into burning rubber. :-\
01Dodge TD
81 Caddy TD
Reply #3October 30, 2010, 11:32:12 am
Re: head swap
« Reply #3 on: October 30, 2010, 11:32:12 am »
exotic?
is a VNT exotic? thats what some of us run, either KKK's, wastegated garretts, and VNT garretts. with the occasional VNT KKK.
