Author Topic: Intercooler question  (Read 3029 times)
October 29, 2010, 12:19:36 pm
Henchman
  • 183
« on: October 29, 2010, 12:19:36 pm »
I have a B3 Passat Wagon with AAZ.  I want to intercool.  I am interested in obtaining either OEM intercooler for my car, but would probably have to get it from Europe (not cheap).  I think I should be able to make an mk3 tdi intercooler work, as I think they sat in more or less the same location (correct me if I'm wrong).  I am also considering a FMIC, as they are inexpensive.
So, will either the stock or tdi intercooler be good for me?  I max out now at 23psi and am concerned about the oem plastic end tanks.  Is there a downside to the FMIC, too big?  Too hard to plumb?
Thanks,
Ian
Under way - 1991 Passat Syncro Wagon w/m-tdi
1991 Passat GL Wagon w/AAZ conversion (now using engine/tranny from 1993 Passat
1993 Passat GL 1.9 Diesel (RIP 385k km, engine, tranny, clutch all original)
Reply #1October 29, 2010, 04:53:42 pm
GEE-BEE
  • 1604
Re: Intercooler question
« Reply #1 on: October 29, 2010, 04:53:42 pm »
Try Bellintercooler.com
Iam going for thin 1-1/2, but at least 18 x 26 with 2' outlet's
Cxracing.com has the best price on tubing
Iam still waiting on my grahmtool tube beader...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2October 30, 2010, 11:23:32 am
« Reply #2 on: October 30, 2010, 11:23:32 am »
23 psi is not good for plastic end caps..
Reply #3October 30, 2010, 01:50:43 pm
Henchman
  • 183
« Reply #3 on: October 30, 2010, 01:50:43 pm »
Good for only 1 trip to 23 psi?  That was my concern....
Reply #4October 30, 2010, 02:11:15 pm
« Reply #4 on: October 30, 2010, 02:11:15 pm »
it may make a few trips to 23 psi.. my HUGE volvo intercooler saw 23 or so psi and it dont leak. but i was told that it was gonna pop around 15 psi.. i dunno tho, for as cheap as intercooler kits are on ebay, i may just go that route.
Reply #5October 31, 2010, 07:37:41 pm
« Reply #5 on: October 31, 2010, 07:37:41 pm »
i think its probably the luck of the draw, too..
