General Information
Upgrades (non engine related )
MK II Radiator Fan Install MKI Caddy
Pages:
Topic: MK II Radiator Fan Install MKI Caddy (Read 10013 times)
Reply #15
November 13, 2010, 07:20:03 am
GEE-BEE
Re: MK II Radiator Fan Install MKI Caddy
Reply #15 on:
November 13, 2010, 07:20:03 am »
Thanx, going to a 1990 dual passat 1.8 fan assy
I moved the radiator far left
this fan uses a drive belt and mounts to the 675 mm 16 v fan
GB
Last Edit: December 25, 2010, 09:53:00 pm by GEE-BEE
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #16
November 30, 2010, 08:51:02 am
GEE-BEE
Reply #16 on:
November 30, 2010, 08:51:02 am »
Update
1990 Passat dual fan will bolt on the 675 mm radiator, It has a belt driving the aux fan
26-1/2 wide x 13 ' tall
I found four new all brass NOS radiators ( behr) Three a/c type and one non a/c type
A/c model's have angle top outlet to clear the alt on 1.6 a/c applications, there also used on the 16 v scirocco 16 v setup
GB
Last Edit: December 06, 2010, 03:59:51 pm by GEE-BEE
Giles Pump OHC
MK1 JETTA DASH
Reply #17
January 08, 2011, 04:22:02 pm
Reply #17 on:
January 08, 2011, 04:22:02 pm »
Reply #18
January 08, 2011, 05:08:49 pm
GEE-BEE
Passat 16V Fan Shroud
Reply #18 on:
January 08, 2011, 05:08:49 pm »
And yes it fits the MK1 with the 675 mm scirocco 16 v radiator
GB
Last Edit: January 10, 2011, 01:31:34 pm by GEE-BEE
Giles Pump OHC
MK1 JETTA DASH
Reply #19
February 03, 2011, 06:23:22 pm
wolf_walker
Reply #19 on:
February 03, 2011, 06:23:22 pm »
As "neat" as that belt driven aux fan is, my first thought is great, something else to fail..
Mentat Text Two
Reply #20
February 04, 2011, 09:32:21 am
GEE-BEE
Reply #20 on:
February 04, 2011, 09:32:21 am »
All new parts installed: fan's and belt
perfect fitment, runs for about 7 seconds after it reaches the 205 mark
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #21
February 19, 2011, 07:29:14 am
macka
Reply #21 on:
February 19, 2011, 07:29:14 am »
what about changing the drives over to something like a Gates power belt set up. you could get better rpm with a smaller hub. just thinking about making the drive set up more reliable. I bet you can get another 30 or 40 cfm extra and no real slippage.
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
Reply #22
March 19, 2011, 11:33:02 am
levi20AE
User+
Reply #22 on:
March 19, 2011, 11:33:02 am »
Do you have any pics of this radiator and fan installed? I would like to see the clearances on each side. Sounds like a great option.
Reply #23
March 19, 2011, 11:10:10 pm
GEE-BEE
Reply #23 on:
March 19, 2011, 11:10:10 pm »
emlail me at
[email protected]
Giles Pump OHC
MK1 JETTA DASH
Pages:
General Information
