Author Topic: AAZ oil filter adapter  (Read 12752 times)
October 24, 2010, 05:48:55 am
vako
  • 187
« on: October 24, 2010, 05:48:55 am »
hello  ;D
 as i'm swapping my suzuki vitara, i needed to replace stock aaz oil filter adapter with the one tilted on the side of the flywheel.  a have bought an adapter from audi (they said that it was from 1.9 diesel, but im not sure which model it was fitted on). today when i removed my stock adapter i found out that there is a little difference, betwwn the adapters.
there is some kind of a valve in the upper hole of audi adapter, but there is no such valve in vw adapter. what should i do?
thank you in advance
Reply #1October 24, 2010, 08:29:56 am
Reply #2October 24, 2010, 09:20:52 am
Re: AAZ oil filter adapter
« Reply #2 on: October 24, 2010, 09:20:52 am »
I can't tell exactly from the pictures but the oil passages look to be the same. If so there shouldn't be a reason you can't use it. If the valve doesn't restrict any of the other passages it is probably for a sender of some sort. I would just try to match the passages up and if they aren't different put it on. Spin the oil pump with a drill and if all is getting oil you are good.
Reply #3October 24, 2010, 10:15:23 am
vako
  • 187
« Reply #3 on: October 24, 2010, 10:15:23 am »
thank you for the reply  :D
i successfully removed that valve from there :D it seemed to be one way valve. except for that my filter housing is identical to the oil filter housing used in AAZ.  so i will install the housing tomorrow :)  (i'm installing it without the valve)
i think this topic will e useful for someone who will try to fit audi filter housing on vw engine :) mostly for swappers :D
Reply #4October 24, 2010, 10:23:43 am
« Reply #4 on: October 24, 2010, 10:23:43 am »
It might be an anti drainback valve. To keep the oil from needing to prime with the filter being in a different orientation??? Either way it should work for you. Just spin it with a drill and make sure you are getting oil.
Reply #5October 24, 2010, 10:57:50 am
vako
  • 187
« Reply #5 on: October 24, 2010, 10:57:50 am »
yes it was a drainback valve, but with that valve there was only little hole for oil to pass through. without the valve there is almost a half an inch hole (there is a big hole in original adapter too) :D  so i think it would be better to leave without valve.
+  i am using the biggest oil filter available :D for maximum efficiency of oiling system.
i had problems with oiling system of my suzuki engine (2 rod knocks in a year  ;D) so  i need to have good oiling system for AAZ. because i need my vehicle for 50/50 on-road/off-road use  ;D
Reply #6October 24, 2010, 11:04:18 am
Quantum TD
  • 1195
« Reply #6 on: October 24, 2010, 11:04:18 am »
The bracket you are trying to install came off a 1.8T (gasser) Audi or Passat. As you've noticed, the valve simply unscrews with an 8mm XZN (triple-square or 12-point tool), the same that is used on the CV bolts on most VWs.
I'm going through this same quandry with my 1.9 AAZ into a 1982 Quantum. I looked at the valve. If you notice, it is a check valve that allows oil BACK to the block.Take a close look at the valve, you'll see that it opens BACK to the block.
I'm not sure why VW/Audi did this, but if you look closely at your original AAZ flange, the internals should be threaded to accept the same check valve (or, a similar valve with a different pressure rating).
As noted, I too am debating on whether or not to leave it in place. Here are some of my thoughts on the matter. Hopefully I can get some expert opinion on this from other members who are more-familiar with turbo applications.
1) The 1.8T has a LONG turbo feed line. It's about 20-30% longer than any TD motor line. I also think it's narrower in diameter. My guess is that the engineers put the check valve in to keep a residual amount of oil in the line for start-ups. This would reduce the initial wear and tear on the turbo for the first second or so when the car first starts. This would be a GOOD thing for ANY turbo application, let alone the 1.8T.
The thing I can't figure out is why they never used them on the earlier cars, DESPITE the fact that most of the oil filter flange housings were tapped and threaded to accept such a check valve.
2) Looking at how the oil flows through the system, it appears that oil enters through the lowest hole, enters the filter, and then is forced through the center pipe up to the head and the turbo. Then there is the secondary port where this check valve is located. BUT, this port with this check valve MAY prevent or reduce oil pressure from going where it is needed. For example, to the intermediate shaft, head or crank. Most 1.8T motors uses a completely different oil pump, and lack an intermediate shaft. This check valve may pertain to those facts.
I too would appreciate any thoughts as to why VW installed this check valve on 1.8T cars, but not 1.9TD (or other models with similar flanges). If it IS in fact for keeping oil in the feed line, then I'm happy to leave it in there. But if it will starve some part of the system, then obviously, I don't want it in there.
« Last Edit: October 24, 2010, 11:07:39 am by Quantum TD »
Reply #7October 24, 2010, 11:57:19 am
« Reply #7 on: October 24, 2010, 11:57:19 am »
wow, you must be REALLY REALLY hard on your Zuki.. i have a couple friends who have sammi's with stock engines (1.3 and 1.6) and they see ridiculous high rpms, and never throw rods. im talking turning soo many RPMs that they dont even sound like an engine anymore, more like a pissed off cloud of bees..
and i would have left the valve in there.. im sure VW put it there for a reason.. they usually do.
Reply #8October 25, 2010, 04:21:33 am
vako
  • 187
« Reply #8 on: October 25, 2010, 04:21:33 am »
[/quote]
[/quote]
but that adapter seems to be from 1.8 turbo gasser. and there is no valve in aaz adapter... i think it would be better if  dont use the valve, because there may be some reasons why they dont use valves on AAZ :S :-\
Reply #9October 26, 2010, 04:39:13 am
blackdogvan
  • 574
« Reply #9 on: October 26, 2010, 04:39:13 am »
What filter are you planning? Use caution, stock is really the only choice.
1991 Vanagon 1.9 mTDI
Reply #10October 26, 2010, 05:15:37 am
vako
  • 187
« Reply #10 on: October 26, 2010, 05:15:37 am »
i've bougt a filter of the size that was installed on an engine when i purchased it. but I have seen aaz-s on different forums  where little oil filters are fitted...  it is on of the best filter brands available here, HENGST. almost everyone in our offroad club uses that brand and noone had any problem so far
Reply #11October 26, 2010, 06:00:23 am
« Reply #11 on: October 26, 2010, 06:00:23 am »
IIRC you can put an old ford filter on this base, but that and the VW gassers send the oil differently. The oil wouldn't be filtered it would just go through the bypass ... like I said IIRC I maybe off, but I wouldn't use anything that wasn't specifically made for the VW diesel engine. Brand doesn't matter as much as the purpose.
Reply #12October 26, 2010, 06:59:50 am
« Reply #12 on: October 26, 2010, 06:59:50 am »
how would it just go thru the bypass and not the actual filter? doesnt seem possible to me..
Reply #13October 26, 2010, 09:46:19 am
Wayland
  • 364
« Reply #13 on: October 26, 2010, 09:46:19 am »
Yes, I hear this argument all the time, but have never heard an explanation. How can a filter that works fine on many other engines, ie Ford, Dodge, etc not work AT ALL on a Vw?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #14October 26, 2010, 09:50:51 am
« Reply #14 on: October 26, 2010, 09:50:51 am »
only way i could see it possible is if its a reverse flow pattern from a VW..
but dont all VWs (and engines for that matter) flow the same way if they have a spin on cartridge?
maybe its because VWs operate at such high oil pressures when they are pretty cold?
still tho, how would a filter that works on something else, not work AT ALL on a VW?!?!?!
i think we need some 'splainin on this topic..
