Author Topic: WTB 1.6 camshaft retainer  (Read 5633 times)
October 21, 2010, 09:58:18 am
Zukiman87
  • 65
« on: October 21, 2010, 09:58:18 am »
I need the number 4 retainer if anyone in BC or fairly close has one.
Reply #1October 21, 2010, 11:00:13 am
Re: WTB 1.6 camshaft retainer
« Reply #1 on: October 21, 2010, 11:00:13 am »
If you are talking about the tops of the cam caps that hold the cam down they are like rod and bearing caps: uniquely machined as matched pairs and so not interchangable.
The good news is that its an easy job for a good machine shop to line bore your existing set...depending on why you need a new one?
Reply #2October 21, 2010, 01:00:33 pm
Zukiman87
  • 65
« Reply #2 on: October 21, 2010, 01:00:33 pm »
I broke one!
Reply #3October 25, 2010, 11:52:12 pm
Toby
  • 728
« Reply #3 on: October 25, 2010, 11:52:12 pm »
How did you manage that?
Reply #4October 26, 2010, 11:15:57 am
Zukiman87
  • 65
« Reply #4 on: October 26, 2010, 11:15:57 am »
Anyone have a full set?
Reply #5October 26, 2010, 11:52:17 am
410
  • 581
« Reply #5 on: October 26, 2010, 11:52:17 am »
U think you might need a head!
Reply #6October 26, 2010, 04:52:45 pm
« Reply #6 on: October 26, 2010, 04:52:45 pm »
its gonna have to be bored bigger, and probably have a bearing installed in the head and new cap.. thats how ive seen them fixed..
Reply #7October 26, 2010, 06:55:19 pm
« Reply #7 on: October 26, 2010, 06:55:19 pm »
They are matched to the head...no good on their own unfortunately.
What you might be able to do is get one to replace the one that broke, have all 4 caps shortened, and then have the head line-bored.
Reply #8October 27, 2010, 06:42:59 pm
Toby
  • 728
« Reply #8 on: October 27, 2010, 06:42:59 pm »
Actually the easy way to do it is to surface the top face of the head about .005", a trivial amount. You can then line bore the cam towers taking most of the meat off of the caps. Set up on the head surfacing is very simple, not so if you are machining the caps.
Reply #9October 27, 2010, 11:56:45 pm
  • 2932
« Reply #9 on: October 27, 2010, 11:56:45 pm »
I feel for ya man.
 A cam cap and some machine work is all it would take to save this head,... if you can find a number 4 cam cap.
That's the one next to the end right?
Not sure about sending to Canada but I've got a few parts heads.
Reply #10October 28, 2010, 09:13:20 am
Zukiman87
  • 65
« Reply #10 on: October 28, 2010, 09:13:20 am »
Ya that's why I'm looking for a number 4 cap. Getting the machine work is no problem.
Reply #11October 28, 2010, 05:52:51 pm
410
  • 581
« Reply #11 on: October 28, 2010, 05:52:51 pm »
I do have cam caps off an aaz head but I take it they are different.  Anyone know?
