Author Topic: Headlight switch wiring question  (Read 3779 times)
October 20, 2010, 11:56:15 am
doonboggle
  • 179
« on: October 20, 2010, 11:56:15 am »
1981 diesel pickup
The left side of the illumination lights for my speedo cluster is dark.  The right side, where I removed the clock to install the tachometer, is lit up OK.  Fuse (#5) checks out OK.
Next culprit is the H/L switch.  So in getting oriented with the wiring by tracing down via Bentley and online long-wired schematic, see the terminals on switch numbered: 2,4,7,31,1,3,5 & 6=total of 8 terminals
Had a fellow give me one a few months ago that supposedly came off of a 1982 pickup; also diesel.  It looks to be darn near brand new.
But in looking at it's terminals, the designations are totally different: 1 ... D ... H ... R ... B2 ... 15 ... B1 ... one unmarked that seems to join 2 internal points ... and what appears to be the ground on the end, out of the group of the others.
Any ideas of what the cross references are to the original numbers?
TIA
« Last Edit: October 29, 2010, 10:15:07 pm by doonboggle »
doonboggle
1981 Rabbit pickup; 1.6L diesel
2006 Jetta TDI
1971 VW Karman Ghia convertible
Reply #1October 29, 2010, 10:16:14 pm
doonboggle
  • 179
Re: Headlight switch wiring question
« Reply #1 on: October 29, 2010, 10:16:14 pm »
Bump.  Hopefully someone knows ...
doonboggle
2006 Jetta TDI
