Author Topic: 1.9 AAZ Suzuki Vitara build  (Read 20352 times)
October 19, 2010, 09:48:21 am
vako
  • 187
« on: October 19, 2010, 09:48:21 am »
hi guys, i live in gorgia (europe) and a'm about to start suzuki vitara/tracker diesel convertion. my stock 8 valve engine had problems from the day the car was bought. as it appeared there was a crack in cylinder block, so repairing is impossible. 4 months ago i bought 1.9 TD egnine for 500$ . the seller gave me a money back guarantee, if there will be any other problems when the engine is started after the swap (but that guarantee had expired :D because i haven't yet started the engine)
 i opened a topic here about my crankshaft spocket. an at the end  i came to the decision that it will use only alternator  and one v belt. no powersteerning for now :(.
 last weekend i fitted engine to vitara angine compartment. only  audi style oil filter adapret and little oil pan modifications are needed. i have also done templates for engine mounts and this weekend i'll make them from 6mm steel plates.
 now i'll post some photos of the project  ;D
my suzi  :D
AAZ the day bought it
after buying diesel engine i was lazy so i continued using my car with it's petrol engine which was not in very good shape  ;D
 ;D
after a little accident 1 month ago (only radiator, hood and one frame tube were damaged)
 i startet with my diesel swap.
at first i disassambled my engine.as i expected there was a rod knock  ;D
and i started getting the parts ready for fitting diesel engine...
Reply #1October 19, 2010, 09:59:57 am
vako
  • 187
Re: 1.9 AAZ Suzuki Vitara build
« Reply #1 on: October 19, 2010, 09:59:57 am »
at first i had my flywheel redrilled to fit vw crank.
but the next day i found out that one hole was rdilled from the wrong side  >:( as i wasnt able to find nex suzuki flywheel i had no oyher way than doing this...
i hope it will work fine :X
here is the adapter plate :) i had no money to buy this plate from "acme adapters" so i had to do it myself  ;D
next step fitting the gearbox to the plate
and fitted to the engine bay  ;D
Reply #2October 19, 2010, 11:04:55 am
vako
  • 187
« Reply #2 on: October 19, 2010, 11:04:55 am »
play between the teeth of the oil pump is 0.2 mm. acording to the service manual it is the max allowed wear. so i thin it will work for 20k kilometers or so :)
« Last Edit: October 19, 2010, 11:18:16 am by vako »
Reply #3October 19, 2010, 11:11:40 am
« Reply #3 on: October 19, 2010, 11:11:40 am »
Looks like a fun project!!
I'd be tempted to replace the oil pump personally... My truck had some scoring like that and decided it wouldn't prime again after an oil change.  Worked perfectly fine until some air got in it - resulted in me being stuck in Regina for several days.  :(
Reply #4October 19, 2010, 11:34:54 am
vako
  • 187
« Reply #4 on: October 19, 2010, 11:34:54 am »
now, before i have started it for the first time, i try to spend as little money as possible, and to start the car as fast as possible. if everything works well i think i'll make some modifications next summer.  because vitara is the only car i have and it also is my daily driver.
    going by bus to the university every day is a real hell for me...  ;D
Reply #5October 20, 2010, 12:19:09 pm
vako
  • 187
« Reply #5 on: October 20, 2010, 12:19:09 pm »
one more question, yesterday when i was checking vacuum pump i noticed that there is some play between the teeth of the intermediate shaft and vacuum pump.      the play isn't serious so i think i shouldnt be worried.
this weekend i'll take my oil pump to the person who sold me my engine and maybe he will exchange it, if he has another pump from aaz :D if he doesn't, than i'll have to use what i have ::)
Reply #6October 20, 2010, 11:47:50 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #6 on: October 20, 2010, 11:47:50 pm »
Does look like a fun project.
I am really not keen on your flywheel though.... I would be worried about cracking between the bolt holes. Flywheels do a lot of damage if they come loose.
'91 Golf Cabrio 1.9TD
Reply #7October 21, 2010, 12:15:56 am
vako
  • 187
« Reply #7 on: October 21, 2010, 12:15:56 am »
 to be honest that did happen to me when i had freshly assembled suzuki engine. i have forgotten to tighten flywheel bolts properly so they came loose after ~20-30 minutes after starting the car  ;D the sound was so loud that i thought it was a broken crank  ??? but when i removed the engine (in suzuki removing the engine is far more easy for me than removing the gearbox ;D)  a found out that fywheel bolts were barely holding themselves in the bolt holes  ;D but there was no damage at all.
 in this case i think that even if that piece, marked with blue, completely breaks away, the bolt will hold it in place. and other 5 bolts will keep flywheel on its place for the other hand....    lets see how it works  ;D if something goes wrong i know how wobbly flywheel sounds ::)
Reply #8October 21, 2010, 04:25:59 am
« Reply #8 on: October 21, 2010, 04:25:59 am »
i need to build one of these for a winter rig...
Reply #9November 02, 2010, 01:11:35 pm
vako
  • 187
« Reply #9 on: November 02, 2010, 01:11:35 pm »
http://www.youtube.com/watch?v=MLpNgajBi4E
oil pressure and leak testing today... i think pressure is perfect
Reply #10November 02, 2010, 06:38:24 pm
macka
  • 957
« Reply #10 on: November 02, 2010, 06:38:24 pm »
vako,
   just fill the holes with 6011 welding rod. Make sure you heat the flywheel first after you prep the surfaces to be welded. I've done that fix on a mitsu flywheel.
Quote from: Vincent Walden
