Author Topic: 85 Golf speedometer cluster?????  (Read 3387 times)
December 31, 2005, 02:41:57 am
LC
  • 9
« on: December 31, 2005, 02:41:57 am »
will the cluster from a gas car fit my diesel? mine does not have a tach but i would like to have one. my odometer does not work on mine. if it will work, what years and what about the glow plug light.  thanks  Lamar
Reply #1December 31, 2005, 07:37:38 am
moTthediesel
  • 194
« Reply #1 on: December 31, 2005, 07:37:38 am »
I've got a Quantum cluster with a diesel tach, but I don't know if that would fit in yer Golf.
Anybody out there know  :?:
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #2December 31, 2005, 07:51:25 am
mpg
  • 49
« Reply #2 on: December 31, 2005, 07:51:25 am »
i put an '83 gti cluster in my "82 straight diesel rabbit, the odometer/speedometer worked fine, but the tach just bounced around after i tried hooking it up in a couple of questionable spots. i believe there is a way to hook up a tach, but i can't find the info
'90 Jetta AAZ T3 lifted
'81 Caddy project
'84 GLi 1.9 16V
'03 GLi 24V 6spd
Reply #3December 31, 2005, 08:52:32 am
zyewdall
  • 393
« Reply #3 on: December 31, 2005, 08:52:32 am »
Try these threads
http://www.vwdiesel.net/phpBB/viewtopic.php?t=76&highlight=tachometer+optical
http://www.vwdiesel.net/phpBB/viewtopic.php?t=151&highlight=tach+optical
I thought I remembered a more detailed one on how to make the optical one which ran off the injector pump pully, but I can't find it now.
Zeke
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #4December 31, 2005, 03:20:09 pm
mortskeg
  • 95
    • http://www.vwcaddy.com
« Reply #4 on: December 31, 2005, 03:20:09 pm »
I went the alternator with w signal and gas tach with signal converter route in my pickup.  I did a write up on it here:
http://vwcaddyforum.com/showthread.php?t=4749
The dakota digital unit works great and also drives my cruise control-
http://vwcaddyforum.com/showthread.php?t=4843
Hope this helps.
