Author Topic: WTB: MK1 Turbo Diesel Airbox / Fuel Filter Mount  (Read 4459 times)
October 17, 2010, 10:14:10 pm
Rhetoric
  • 12
« on: October 17, 2010, 10:14:10 pm »
I know it's going to be next to impossible to find these parts, but I thought I would post anyway to see if anyone has these and wants to part with them.
Email me: [email protected] or send me a PM here. :)
Reply #1October 17, 2010, 10:49:44 pm
Quantum TD
  • 1195
Re: WTB: MK1 Turbo Diesel Airbox / Fuel Filter Mount
« Reply #1 on: October 17, 2010, 10:49:44 pm »
FYI. The small bracket with the rubber mounts looks quite similar to the one on my 1982 Quantum TD. Might be the same.
Unfortunately, the heat shield did not come on the Quantum, so you'd still have to source that (and presumably the rubber hoses?).
For the airbox, I'm told the early Rabbit carbed box is quite similar, but not exactly the same. But, the bracket that holds it to the inner fender is exactly the same (it gets welded on).
Good luck. If you happen to get flooded with emails, let me know. I wouldn't mind having a setup myself.
Reply #2October 18, 2010, 12:13:31 am
GEE-BEE
  • 1604
« Reply #2 on: October 18, 2010, 12:13:31 am »
You will  find them on te vwvortex or Samba
I make the snorkel's for the MK1 TD, either turbo
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3October 18, 2010, 05:41:22 am
Rhetoric
  • 12
« Reply #3 on: October 18, 2010, 05:41:22 am »
Thanks for the tips, you guys.   :)
@GEE-BEE: I'll be looking to buy the snorkel you make once I get the airbox.  ;D
Reply #4October 18, 2010, 05:08:04 pm
GEE-BEE
  • 1604
« Reply #4 on: October 18, 2010, 05:08:04 pm »
There made for either turbo
Outlet's the same , Inlet is different
I made the mandrell to make either
KO3
T2/T3/K14/K24
Custom color or matte is a option
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #5November 08, 2010, 05:37:49 am
Rhetoric
  • 12
« Reply #5 on: November 08, 2010, 05:37:49 am »
Bumping this up. Still looking for the fuel filter mount and heat shield!  :)
