Author Topic: running and then nothing...  (Read 4888 times)
October 16, 2010, 03:05:36 pm
Naturally Aspirated
  • 27
« on: October 16, 2010, 03:05:36 pm »
so my 1.6 NA was running fine after an intermediate shaft seal replacement. Then out of nowhere it starts to sputter and wouldnt restart.
replaced the seal after it fell out of the block causing me to drop most of my oil on the ground. Got it towed home and noticed oil came out the dipstick and the oil cap. Why would that happen???
Any and all help will be greatly appreciated.
Just to note, it started again after it ran rough and i shut it down. But it was running rough and then i went to give it gas and it stalled.  ???
Reply #1October 17, 2010, 09:51:24 am
Naturally Aspirated
  • 27
Re: running and then nothing...
« Reply #1 on: October 17, 2010, 09:51:24 am »
Update: now it wot start at all. ???
Reply #2October 17, 2010, 01:48:01 pm
« Reply #2 on: October 17, 2010, 01:48:01 pm »
How did you time the engine when you replaced that seal? I bet it is out somewhere to cause those problems.
Reply #3October 17, 2010, 01:54:08 pm
Naturally Aspirated
  • 27
« Reply #3 on: October 17, 2010, 01:54:08 pm »
i double checked the timing after and rotated the engine a few times to ensure the timing is right. I also checked the pump setting and its at .95 which is where it should be. I tried advancing it and i tried retarding it to get little or no change. I would imagine if the compression went to *** in the cylinder(s) it would not start right? I have a feeling that the syptoms of the seal being pushed out and the oil coming out the dipstick and oil cap would be a good indication i have serious blowby causing high crankcase pressure.
any and all thoughts are welcome. I padi 900 for the car a year ago. It has 402K kms on the engine so it owes me nothing. I might just called the time of death...
Reply #4October 17, 2010, 11:06:14 pm
  • 2932
« Reply #4 on: October 17, 2010, 11:06:14 pm »
MK2?
 If so; drill out the restrictors to reduce block pressure.
Not sure why it won't run.
 Fuel getting to everywhere?
Reply #5October 17, 2010, 11:53:26 pm
« Reply #5 on: October 17, 2010, 11:53:26 pm »
Pull the oil cap with it running and see how much blowby it's got.
Reply #6October 18, 2010, 06:13:24 am
Naturally Aspirated
  • 27
« Reply #6 on: October 18, 2010, 06:13:24 am »
Well i cant pull the oil cap cause it wont run period. It seems like it will start and run on two cylinders then just stall out. I think I had blowby and then the rings just gave and now i have poor compression causing one or more cylinders to not ignite.
I get an absolute ton of grey exhaust when i turn it over too. I'll step out of the car and get surrounded by it. ???
Reply #7October 22, 2010, 11:36:01 pm
RustyToy
  • 51
« Reply #7 on: October 22, 2010, 11:36:01 pm »
MK2?
Care to elaborate on this?
The diesel fleet:
Smaug - '86 F-250 4x4 6.9L with Banks turbo
Nameless -1965 GMC PD4106 with DD 8v71,4sp
Friggenbroken - '85 VW Golf,1.6IDI,5sp
Friggenslow - '90 Wolfsburg Jetta
1984 VW Rabbit 1.6NA,4sp
The Ton - '79 Chevy CC/dually 'camper special' 6.2L transplant
Reply #8October 24, 2010, 08:10:12 pm
« Reply #8 on: October 24, 2010, 08:10:12 pm »
;D Just keep turning it over. You've got air (gray smoke) in your fuel lines. You've gotta purge the injectors. Get another car to boost you, and keep cranking in 15 second bursts with rest periods in between till it fires.
I can almost guarantee %100 your car starts. :P Goodluck
Reply #9October 29, 2010, 09:43:10 am
« Reply #9 on: October 29, 2010, 09:43:10 am »
grey smoke means there is fuel, but most likely not enough heat to ignite it. so either you got a slightly weak starter/battery/wires, some burned out glow plugs, or something along those lines..
Reply #10November 02, 2010, 08:25:11 pm
« Reply #10 on: November 02, 2010, 08:25:11 pm »
He says he gets surrounded by the smoke, meaning its hot enough in there to half burn the diesel fuel. I think it just needs more purging..
What does this sentence mean? you had blowby? the rings gave? Past tense? now i have poor compression? Present tense? what happened to the motor for the rings to give and the compression to drop? is this confirmed or a theory?
