Author Topic: AAZ dyno results (with plot and video)  (Read 4403 times)
October 15, 2010, 03:51:10 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« on: October 15, 2010, 03:51:10 am »
Hey fellas,
I dyno'd my AAZ today...
thats at the wheels. I'm pretty happy.
Turbo - Merc T3
Pump - fuel screw turned up a little, 1.5mm shim on the main spring in the governor, 1.6TD pin
Injectors - stock
Front mount Inter-cooler
Stock internals
Stock inlet manifold
2.5" exhaust and downpipe, with resonator and rear muffler
video - http://www.youtube.com/watch?v=DC1VeOgegac
« Last Edit: October 15, 2010, 04:15:59 am by gldgti »
'91 Golf Cabrio 1.9TD
Reply #1October 15, 2010, 04:26:57 am
MJF
  • 581
Re: AAZ dyno results (with plot and video)
« Reply #1 on: October 15, 2010, 04:26:57 am »
Which one is the real torque? 225nm which plot shows or 189nm what it says ???
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2October 17, 2010, 05:49:26 pm
gldgti
  • 488
« Reply #2 on: October 17, 2010, 05:49:26 pm »
189... I dont know why the scale is wrong. I might go aske them for another plet with correct scale.
Reply #3October 17, 2010, 08:47:39 pm
RadoTD
  • 513
    Stage WTF
« Reply #3 on: October 17, 2010, 08:47:39 pm »
That's cool! Are you blowing any black smoke at all? How high does your EGT get on a run like that?
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #4October 18, 2010, 12:21:32 am
gldgti
  • 488
« Reply #4 on: October 18, 2010, 12:21:32 am »
on the dyno run, there was some black smoke, but not much (see the video, but note that the wall behind the dyno is already stained with soot). I have since given it another 1/4 turn in on the fuel screw.
Last night I did a very long (3rd, then 4th gear) pull at full throttle. I happily noted the EGT didnt see over 620C, so thats pretty good. I imagine on the dyno it would have been similar or less.
