Author Topic: 1.6TD Build With GT1548 and 11mm Rotor/Head  (Read 13757 times)
October 13, 2010, 09:08:17 pm
taterade
  • 16
« on: October 13, 2010, 09:08:17 pm »
I started a post months ago about this build and I am getting very close to putting it all together. It's going into an 82' rabbit pickup that is pretty solid and clean, although i've molestered it a bit now.  The plan is to do engine and tranny swap now then do body and paint after everything is in proper working order.  It is a full rebuild on both the engine and the transmission with some mods and custom exhaust. I have a bunch of pics to post right now and I will keep posting as I go.
this is a terrible pic to show my rabbit pickup but it's the best i have at the moment
the engine to start with. initially i thought it was a td motor only to find out it was an NA block with a turbo head.
prothe's 1.6td piston set
my garrett gt1548 for good measure
bought a new head for it because the previous owner had the cracks between the valves repaired but not very well done
had the pressure valve welded shut along with the optional backside inlet
re-bushed rods with raceware bolts
freshly polished and balanced crank
since i am going to push this engine a bit i had the oil galley taped for squirters
i am going to convert the filter system to the newer mk4 style setup
aba trans can't remember the code..
all torn down
and cleaned up
welded up the flange to a 2.5" adapter
then welded up one side for the v-band clamp setup
arp studs came the other day! yayy!!!
welded up the exhaust with my buddy. 2.5" mandrel bent
primed/sealed the block after i wire brushed it and cleaned it up all nice
all painted green!!!
shot of the squirters. that's it for now and i'll keep it going as the pump gets rebuilt and so one. i am way stoked to get this in and running.
Reply #1October 13, 2010, 11:19:41 pm
Re: 1.6TD Build With GT1548 and 11mm Rotor/Head
« Reply #1 on: October 13, 2010, 11:19:41 pm »
Looks like you're doing everything right at least, I haven't heard anything bad about prothe pistons yet. They're the only thing he seems proud of.
Keep it up :).
Reply #2October 13, 2010, 11:37:54 pm
« Reply #2 on: October 13, 2010, 11:37:54 pm »
Oh, it also looks like seal grooves at each end of the crank.  You might consider Redi-sleeves.  I'll look the part #s up if you need them.
You are observent.
I think I've heard of oilers that work for this application that don't have a separate bolt hole but rather use a hollow bolt with a squirter sticking of the head........I'll go do a search for it........
Reply #3October 13, 2010, 11:56:03 pm
Reply #4October 14, 2010, 06:01:18 pm
taterade
  • 16
« Reply #4 on: October 14, 2010, 06:01:18 pm »
The picture of the machined holes for the oil jets doesn't seem to show the holes for the bolts that hold them in place.  Was the picture taken prior to machining those holes or are they held in place some other way?
actually i am using a later oil squirter from a 1.8t where it is a basic banjo fitting, so no screw/bolt needed. you are right about the seal grooves though and i think it may be ok. i am going to run it and see how it goes. if i have issues then ill address them then i guess. i would like to see the info on the sleeves however.
Reply #5October 14, 2010, 09:20:49 pm
taterade
  • 16
bottom end
« Reply #5 on: October 14, 2010, 09:20:49 pm »
got most of the bottom end done.  should have it finished up tomorrow and then i am ordering an mls gasket this next week. hopefully i can have it together in a few weeks!
Reply #6October 15, 2010, 05:04:21 am
« Reply #6 on: October 15, 2010, 05:04:21 am »
Just an FYI you might want to consider. The Arco pistons many have said to be good here. I am using them as I got them before I knew about that guy ::) But I am not using the rings that came with them. Several on here have reported oil usage and one guy took his block apart under 10,000 miles and one of the rings were cracked.
SO, you might want to get a different set of rings before putting that MLS HG on...That is what I did. I had the crank in and out 4 times before getting everything I wanted done. If I would have only known I wanted it all at the same time I would have only done it once.
Goetze rings are good I hear.
Reply #7October 15, 2010, 08:42:53 am
Quantum TD
  • 1195
« Reply #7 on: October 15, 2010, 08:42:53 am »
I want to think there was a difference in opening pressures on these squirters (like, between gasser and diesel)
Also (hard to tell from the pic), did you have to machine the block for the squirters?
Reply #8October 21, 2010, 09:06:29 pm
taterade
  • 16
« Reply #8 on: October 21, 2010, 09:06:29 pm »
the squirters have a very low breaking pressure. mostly used for idle pressure to rise and then they break after a little raise in the rpm's. it shouldn't be a problem using the 1.8t squirter.
cleaned manual rack!
put a few things on the block tonight and remembered i never posted anything about the oil cooler i am putting in. i will post more pics of the oil cooler setup tomorrow.  i am hoping to have everything i need by the 12th of next month.  if all goes to plan it should work out. see ya later
Reply #9October 22, 2010, 04:22:18 am
  • 3468
    • McScrubbins Body Wash
« Reply #9 on: October 22, 2010, 04:22:18 am »
I'm running Goetze at high boost & fuel. Still going great. I ran the car for a while with the breather just dumping to atmosphere and it was clear as glass coming out. no oil moisture and that's around 5,000km.
Remarkable work so far. Very impressed :)
Also, i added an oil cooler exactly as you are but be careful of where your lines join those nipples on the plate. I used compression fittings on steel braided line on the cooler and just managed to squeeze the line hard enough with small t-clamps on the plate side. (before i damaged the set up... stupid me)
Keep a film of oil on all the machined surfaces until its time to button it together.
Reply #10October 22, 2010, 06:02:17 pm
taterade
  • 16
« Reply #10 on: October 22, 2010, 06:02:17 pm »
thanks for all your input and your kind words of the work. i have kept a light layer of oil on it ever since i got it back from the machine shop. i'm really pushing hard to get it all together within the next couple of weeks.  :)
Reply #11December 04, 2010, 07:00:03 pm
taterade
  • 16
« Reply #11 on: December 04, 2010, 07:00:03 pm »
been a little bit. obviously i didn't hit my goal of getting it done last month and it looks like it'll still be a few more months. here is what i did today.
got the bottom end all torqued and the head studs installed
got the head torqued down and turbo on with a few other things
this is just a coolant supply freeze plug from a 2.7t and i believe later vr6's. made it easy to supply coolant for the turbo coolant jacket
Reply #12December 05, 2010, 10:30:18 am
carrizog60
  • 978
« Reply #12 on: December 05, 2010, 10:30:18 am »
isnt 11mm head for a gt15?
what pressure are you going to hit on that turbo?
is a bit on the small side...
Portugal
Reply #13December 06, 2010, 09:59:09 am
« Reply #13 on: December 06, 2010, 09:59:09 am »
11mm pump head is gonna be too big on your setup.. its gonna supply TONS of fuel, when you will only need a little bit.. that utrbo isnt gonna be big enough to take advantage of an 11mm pump.
Reply #14December 06, 2010, 10:10:55 am
« Reply #14 on: December 06, 2010, 10:10:55 am »
I think the turbo choice is fine, one can always turn the pump down to tune it properly.
Nice looking build.
