Author Topic: Head Questions  (Read 2021 times)
October 13, 2010, 06:53:38 pm
Zukiman87
  • 65
Head Questions
« on: October 13, 2010, 06:53:38 pm »
I just pulled the heads of both my engines to check out the better one to use on my build. One was the 10mm hex and the other was a 12 mm triple square. I know they should be different hole sizes but I measured the bolt holes with my digital caliper and they are the exactly the same size. I was going to use my 10 mm head on my 12 mm block because it has no cracks between the valves. Is it safe to use it or do I have to modify it to fit the block?
Reply #1October 13, 2010, 07:04:09 pm
Mark(The Miser)UK
  • 1557
Re: Head Questions
« Reply #1 on: October 13, 2010, 07:04:09 pm »
Check and allow for the difference in head bolt hole depth.
Mark-The-Miser-UK
