Author Topic: crank stiffer to turn after ring replacement, typical??  (Read 2610 times)
December 29, 2005, 11:52:35 am
towns
  • 20
« on: December 29, 2005, 11:52:35 am »
I just finished installing 2 of the 4 pistons back into the engine after replacing the rings (1.6 TD), and as I was turning the crank, it seemed much stiffer (harder) to turn than when I had been turning it with the original rings.  Is this stiffness typical after a ring replacement?
Reply #1December 29, 2005, 12:12:03 pm
vwmike
  • 1158
« Reply #1 on: December 29, 2005, 12:12:03 pm »
It's typical for an engine to be tighter with new parts installed. That is why when you buy a new tdi it will get progressively better mileage through break-in.
Reply #2December 29, 2005, 02:29:05 pm
towns
  • 20
« Reply #2 on: December 29, 2005, 02:29:05 pm »
i should also mention that i installed new connecting rod bearings
Reply #3December 29, 2005, 03:42:38 pm
towns
  • 20
« Reply #3 on: December 29, 2005, 03:42:38 pm »
I found one possible reason for the tightness in the crank.  Following the Bentley's instructions on piston installation can be slightly confusing, it turns out i installed the upper piston rod bearing (on piston side) the opposite way and not in the groove...  :oops: Good thing i caught it before i went any further.  This must have played a role in the extremely stiff crank.
Reply #4December 29, 2005, 03:45:53 pm
vwmike
  • 1158
« Reply #4 on: December 29, 2005, 03:45:53 pm »
Yeah, that would've been bad. I'm not sure you want to use that bearing anymore though.
