Author Topic: Replacing dual mass flywheel?  (Read 4155 times)
October 12, 2010, 04:57:05 pm
dieselherb1
  • 354
« on: October 12, 2010, 04:57:05 pm »
I've got a engine from a 01 Beetle it has a dual mass flywheel. I'm installing into a 00 Jetta, don't know what flywheel it has, but want to use solid flywheel. Easy swap?
Reply #1October 12, 2010, 05:29:27 pm
rallydiesel
  • 1880
Re: Replacing dual mass flywheel?
« Reply #1 on: October 12, 2010, 05:29:27 pm »
You will need the G60 flywheel. I don't know what size clutch the A4 has but you will probably need a VR6 clutch to match up with the G60 flywheel.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 12, 2010, 09:39:33 pm
Powered by Spearco
  • 1203
« Reply #2 on: October 12, 2010, 09:39:33 pm »
The G60 FW and VR6 FW are 228mm. The VR6 PP and disc are a direct swap into a 4cyl. 02A/02J trans. using a G60 FW.  :)
As far as the swap goes, yes. Other than the special socket for the DM FW. I think its a 10 or 12 tripple square.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #3October 12, 2010, 09:50:29 pm
Syncroincity
  • 727
« Reply #3 on: October 12, 2010, 09:50:29 pm »
Check Ebay for solid flywheel & clutch packages, search tdi flywheel.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #4October 12, 2010, 10:13:16 pm
Powered by Spearco
  • 1203
« Reply #4 on: October 12, 2010, 10:13:16 pm »
ECS Tuning has a couple of G60 FW's. Stock and lightened fairly cheap.
'13 Golf R:. Tuned
'98 Puch G320
Reply #5October 13, 2010, 08:04:33 pm
dieselherb1
  • 354
« Reply #5 on: October 13, 2010, 08:04:33 pm »
What is the difference between the G60 flywheel and the 1Z-AHU?
Reply #6October 13, 2010, 10:35:05 pm
Powered by Spearco
  • 1203
« Reply #6 on: October 13, 2010, 10:35:05 pm »
The G60 and the AHU transmissions are cable shift. The 1Z, I'm not sure of what type of trans they came with?
'13 Golf R:. Tuned
'98 Puch G320
Reply #7October 14, 2010, 04:49:59 pm
dieselherb1
  • 354
« Reply #7 on: October 14, 2010, 04:49:59 pm »
The 1Z is the same as the AHU, cable shift.
Reply #8October 14, 2010, 11:13:38 pm
Powered by Spearco
  • 1203
« Reply #8 on: October 14, 2010, 11:13:38 pm »
Ya learn something every day. Thanks.
'13 Golf R:. Tuned
'98 Puch G320
