Author Topic: 1.6TD complete and ultra clean  (Read 3832 times)
October 12, 2010, 09:58:09 am
deathhare
  • 74
« on: October 12, 2010, 09:58:09 am »
SOLD
This motor is 100% ready to go.
Freshly rebuilt bottom end and head with all new German parts. Block was bead blasted and cooked before being rebuilt by a local, reputable, Euro engine builder.
Valves and seats all re-cut
ARP rod bolts
AAZ headgasket
Rebuilt TD injectors
Rebuilt Injection pump
Rebuilt T3 turbo and wastegate
New Glow Plugs
New water pump
New TD metal injector supply lines
New seals and gaskets replaced everywhere
New oil drain line
New hoses everywhere
New Sachs 16v clutch
New belts
New timing belt tensioner
New oil pressure sensors
New injection pump supply line (not pictured)
Lightened Eurospec flywheel
Giles pop valve delete
Rubber valve cover gasket conversion
Rubber pan gasket
I have the timing belt cover set that I will throw in. (not pictured)
I have an mk2 TD airbox and intake tube that I will include. (not pictured)
I may have left something out but basically everything is new or like new. Please ask.
It looks as good in person as it does in the pics. Runs strong and idles perfectly. Made a solid 11psi of stock boost. 5000 miles on it and is ready for 200,000+ more.
I have over $4500 in this motor.
Located in Nashville, TN
This motor will hit ebay very quickly if it doesnt sell soon on the tex.
$2699 obo
« Last Edit: October 17, 2010, 06:46:48 pm by deathhare »
Reply #1October 12, 2010, 03:33:12 pm
Re: 1.6TD complete and ultra clean
« Reply #1 on: October 12, 2010, 03:33:12 pm »
Is the tensioner pulley lip really dented?
Reply #2October 12, 2010, 06:14:19 pm
deathhare
  • 74
« Reply #2 on: October 12, 2010, 06:14:19 pm »
Its not dented at all.
Its just the light making it look that way.  ;)
