Author Topic: Polishing AAZ valve cover  (Read 5655 times)
October 11, 2010, 06:04:43 pm
xxkoadyxx
  • 179
« on: October 11, 2010, 06:04:43 pm »
Hey i was wondering if it it possable it polish a AAZ valve cover? i think so, but not sure what type of metal it is made out of? Any ideas? Thanks
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1October 11, 2010, 06:55:09 pm
Re: Polishing AAZ valve cover
« Reply #1 on: October 11, 2010, 06:55:09 pm »
I am not sure of the metal but whatever it is can be polished. If it is aluminum it is good to give it a clear coat afterwards so it doesn't corrode. If it is steel it is good to give it a clear coat so it doesn't rust.
Reply #2October 11, 2010, 10:48:10 pm
« Reply #2 on: October 11, 2010, 10:48:10 pm »
pretty sure aaz just has a stamped steel valve cover. not that cool to polish..
Reply #3October 11, 2010, 11:03:49 pm
RadoTD
  • 513
    Stage WTF
« Reply #3 on: October 11, 2010, 11:03:49 pm »
It's just steel, but can still look good polished up.
I'd probably go a 2 or 3 stage; start with a greaseless cutting compound, then probably black polishing compound and I'm not sure what would be the best for a final polish, possibly the blue compound? Make sure you've got a separate buffing wheel for each compound though!
Once you're done that, a good clear coat would be the best way to seal it up and keep it shiny.
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #4October 12, 2010, 12:45:27 pm
xxkoadyxx
  • 179
« Reply #4 on: October 12, 2010, 12:45:27 pm »
ok thanks :D
Reply #5October 12, 2010, 01:13:25 pm
catlin_cava
  • 1954
« Reply #5 on: October 12, 2010, 01:13:25 pm »
Just paint it with Chrome Spray bomb lol
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #6November 04, 2010, 05:10:57 am
Henchman
  • 183
« Reply #6 on: November 04, 2010, 05:10:57 am »
Or....  Get a can of weathered gold paint (makes it look like old cast gold whatevers).  That's pimpin!
Now you've go me thinking!
Doesn't matter, it's just going to be covered in oil from the many seeps out of the valve cover anyways!
Anyone want valve covers to play with?  Got tons!
Ian
