Author Topic: Soooooold  (Read 3680 times)
October 11, 2010, 12:18:00 pm
ObscuredByClouds
  • 98
Soooooold
« on: October 11, 2010, 12:18:00 pm »
SOLD.
« Last Edit: November 02, 2010, 04:42:35 pm by ObscuredByClouds »
Reply #1October 19, 2010, 11:00:32 am
Quantum TD
  • 1195
Re: EXCELLENT shape 12mm mechanical N/A head
« Reply #1 on: October 19, 2010, 11:00:32 am »
Since the lifters are out, if you have a spare cam laying around, set it in the journals. If it rocks side to side, then the head is warped (or was warped at one time). You can also just look at the bearing caps. If there is excessive wear in either the #1 or #5, then the head is warped (or was warped at one time). Finally, you can check the deck for warpage with a straight edge or feeler gauge. This type of information should help you assuage some fears, and sell it faster.
Having said that, it looks like a clean head with no cracks between the valves. May have had an easy life.
