Author Topic: Need help. I just messed up bad..  (Read 3753 times)
Reply #15October 08, 2010, 07:03:24 am
Re: Need help. I just messed up bad..
« Reply #15 on: October 08, 2010, 07:03:24 am »
Yep....
BUT I turn it over more than that just to make sure*maybe 4 times as I am pariniod about it*. AND when done turning by hand you should be able to put all the locks back into place without much effort. If it is way off then loosen and repeat.
Libby will also tell you to make sure the slack part of the belt is in the tensioner area. Do that by making sure there isn't slop in between the IP and cam / IP and crank.
Reply #16October 09, 2010, 09:05:18 am
  • 2932
« Reply #16 on: October 09, 2010, 09:05:18 am »
The standard cam locker is a little too thin,..
 but the 10/13 wrench in the spare tire tool kit fits real nice,..
the wrench ends are raised slightly to lift it like the shim that is normally used.
Reply #17October 14, 2010, 02:49:08 pm
  • 3468
    • McScrubbins Body Wash
« Reply #17 on: October 14, 2010, 02:49:08 pm »
I like to use a file as suggested to hold the cam. Also, the IP pulley is spring loaded sort of speak so its tough to get it where you want it. The trick is to put your ratchet on the IP pulley and hold it where you want. Then clamp the belt to the tensioner or the cam pulley (just to keep it taught). That way you can ensure you get the belt nice and tight between the crank and the IP pulley. I've ran into huge issues with slack there causing massive timing problems. It's gotta be tight. There is an exact number of teeth that can be between the pulleys sort of speak.
I hope that helps although from the sounds of it you've already solved the problem.
