Author Topic: MK1 TD SNORKEL'S ( New Production )  (Read 3544 times)
October 07, 2010, 06:03:44 am
GEE-BEE
  • 1604
« on: October 07, 2010, 06:03:44 am »
There done !
ebay item 270645783732
t2/t3/k14
KO3 model
ebay item :360307804767
Enjoy !
Gee-Bee
I will make MKII if there is interest ....
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1October 07, 2010, 02:51:27 pm
jack's lack
  • 275
Re: MK1 TD SNORKEL'S ( New Production )
« Reply #1 on: October 07, 2010, 02:51:27 pm »
Any chance we can get them in blue?
They look awesome btw and so do all the other silicone bits you have been emailing me pictures of. I am going to have to get some from you at some point.
Any plans to make the radiator hoses too?
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #2October 07, 2010, 04:21:02 pm
« Reply #2 on: October 07, 2010, 04:21:02 pm »
Those look great!!!
Reply #3October 07, 2010, 06:36:10 pm
GEE-BEE
  • 1604
« Reply #3 on: October 07, 2010, 06:36:10 pm »
yes I will do a blue for you
Iam doing the upper 1991 1.6 td hose ( silicone )
and the best fitment is the 16 v scirocco lower hose ( a/c ) model
these two are for the 675 mm radiator ( scirocco a/c )type install
a/c model radiator has a lh angled top and a lower outlet facing down, the fan switch sensor is on the front , not the side and you may also use a MK1 or MKII fan support
Fit's mk1's as long as you get the two radiator brackets and pin bumper's ( 9.00 )
you will need a MKII wiring harness to use the 250 watt two speed fan thou.
 MK1 is three blade 150 watt motor, MKII is five blade 250 watt
Want a pic ?
the others are in production
068121053 e , done
191121101 AK 91 JETTA /Golf 1.6 A/C Upper radiator
( fit's MK1 675 mm radiator)
191121051 P Lower 1.6 td jetta / golf
53321051 a    Lower scirocco 16 v a/c  ( fit's MK1 675 radiator)
055121063 a ( reducer ) mk1 ( metal hardlaine to firewall hose )
171121611 E ( firewall to head )
These will complete my installation
all color's, RED, BLUE , BLACK, YELLOW
Gloss or matte Finish
Gee-Bee
Hey jack post a pic for me
I have a  068121053 E, in blue with your name on it, pump to head coolant hose and per your suggestion ( it's 1/2 ) longer
« Last Edit: October 08, 2010, 06:08:07 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #4October 08, 2010, 04:46:44 am
jack's lack
  • 275
My Build Thread
Reply #5October 08, 2010, 06:10:38 am
GEE-BEE
  • 1604
« Reply #5 on: October 08, 2010, 06:10:38 am »
1.9 AAZ Engine Set 105.00 for a set of ( 3 )
068121053E 25.00
GB
Coming soon MKII TD Snorkel and 1.9 AAZ MKIII Snorkel ( either size turbo inlet )
You can get them with no logo for twice the price !!!!
« Last Edit: October 08, 2010, 06:20:56 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
