How much oil consumption?
Topic: How much oil consumption? (Read 2563 times)
October 03, 2010, 08:43:56 pm
ffgb
October 03, 2010, 08:43:56 pm »
What is the normal oil consumption with a rebuilt engine and rebuilt head with about only 2700 miles? I have put about 1-1.5 quarts in about 500 miles. This happened when I switch from Rotella 15w-40 to Mobil Delvac 1300 15w-40 about 500 miles ago. With the Rotella, the oil consumption was about 1/2 qt every 700 miles since the rebuild.
October 04, 2010, 09:28:52 am
arnold
Re: How much oil consumption?
October 04, 2010, 09:28:52 am »
My rebuild engine (block,head and turbo)with now 28.000miles has ZERO oil consumption between the 3000-3500 mile oil change,it will consume some but never drops under the top fill mark,i use castrol gtd oil.
I do remember it using some oil the first 2-3 thousand miles
October 04, 2010, 09:41:25 am
jack's lack
October 04, 2010, 09:41:25 am »
I just drove 1,200 miles to H2O and back. Oil consumption for the trip was 1/4 quart or a cup. This seems to be normal for my rebuild.
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
October 04, 2010, 02:47:38 pm
October 04, 2010, 02:47:38 pm »
I have only ran Rotella 10w-30 and have 700 or so miles on it. I have only used about 8-10 oz in the 700 miles. I used none for 300 and then started running higher RPMs and immeadiately used the 8-10. I have continued to drive in high RPMs and in the last 250 miles I haven't used any. I am going to Rotella 15w-40 at 1,000 miles and hope to not burn any oil for several hundred thousand after that.
When breaking it in I am not letting it idle for really any amount. I am always varying the RPM and try to keep a contant load on the rings. Whether pulling a hill in fourth or fifth or coming down a hill using the engine to hold me back in 3rd. I don't know if it is correct, but I am not using oil so I am sticking with it.
I don't plan on switching to synthetic until about 10,000 miles. I have heard mixed answers about switching on new engine, but 10,000 always seems safe so that is where I plan to do it.
Round 2
October 04, 2010, 09:03:33 pm
ffgb
October 04, 2010, 09:03:33 pm »
I wonder if I should switch to 10w-30 because it is a little thinner, maybe help out with ring sealing a little better? I did an aggressive break-in the first 20 miles to seat the rings, along with varying rpm's to the present. I wonder if its the Grant rings needing a little more time seating because the machinist who did the block work stated the finishing hone is much finer than usual due to his upgraded machine. Just a thought.
October 04, 2010, 09:47:29 pm
Dakotakid
October 04, 2010, 09:47:29 pm »
For what it is worth: my VOA trained mechanic friend, who is now a field-mechanic for the local Cateprillar dealer, recently told me that Cat is no longer supplying 15-40 Cat oil on any leased equipment that they are responsible for servicing. This is due to system-wide higher oil consumption and the mechanics were simply told that the latest formulation of 15-40 is too good at lubing and the rings are pulling away from the walls.
They are now supplying 10-30 Cat oil (year-around) to all equipment and oil consumption has subsided. I had a hard time believing him at first when he said that. Apparently they do no anticipate additional wear in the engines. I keep hoping he will drop off a 55 gallon drum of the stuff at my house..........
October 04, 2010, 10:28:21 pm
ffgb
October 04, 2010, 10:28:21 pm »
Thanks for the input. I guess it does make sense, since viewing the Rotella site, the new formulation has decreased engine wear. I guess it's important that I should of used something like Mobil 5000 10w-30 instead of the Rotella 15w-40 or Mobil Delvac 1300 15w-40 initially. I used the Rotella because it is conventional, but I'll dump the Mobil Delvac 1300 15w-40 and fill it up with 10w-30 CF oil. Put about 5000 miles on the 10w-30, then the next oil change maybe put 15w-40 or stick with the 10w-30. Thank you.
