Author Topic: FS/WTT: 1992 Jetta 8v in Eastern, NC.  (Read 4222 times)
September 29, 2010, 10:53:10 pm
JBR8517
  • 20
« on: September 29, 2010, 10:53:10 pm »
Some of you may recognize this car, I picked her up from another member here in May of 2009 in a trade for my '85 Golf diesel. But I miss that diesel bad, especially with currently putting nearly 1000 miles a week on this Jetta.
***Looking to trade for a Mk2 Diesel (NA or TD) with no serious body or rust issues.
But if I were to put an outright sale price on it, I'd be looking for $2100 obo USD.
If I get my asking price, I'll include the Aero frontend and a serpentine belt conversion (alternator, ABA bracket, ABA/VR pulleys, and a new tensioner).
No oil or coolant leaks!
31-33 MPGs Highway (I do a LOT of road trips)
Odo broken when I bought it at 130,xxx so replaced with the current cluster at 280,xxx.
Mileage now reads 303,xxx and I would estimate true mileage <200,000 miles.
I am daily driving this car so the mileage is only going up.
Engine: (All done in the last year)
8V GTI OEM Dual outlet manifold
New Factory Replacement Catalytic Converter
2.5" mandrel-bent Cat-back with Dynomax muffler
New O2 Sensor (5/10)
Ingen Intake Tubing (larger diameter w/silicone connections)
AC and Power Steering Deleted
G12 Conversion
Spark Plugs (7/09)
New heater hoses (10/09)
New cap and rotor (9/10)
New Top Radiator hose (4/10)
New Timing Belt (10/09)
New V-belts (10/09)
New Battery (12/09)
Suspension/Tires/Wheels:
Manual Steering Rack*
Vmaxx Coilovers
Autotech Front Swaybar
Recent alignment
Poly bushings throughout
Rear Disc conversion
Stainless brake lines
New pads all around (1 month ago)
14" Steelies with sweet OEM hubcaps
195/70 BFGoodrich Touring T/A (balloons)
*When rack was installed (by me), I took the car for an alignment and a few weeks later noticed the steering boots are torn, the only thing I could imagine happened was that they were binded when the technician was performing the alignment and tore then. Its a shame it was never mentioned to me.
Exterior:
Professional-looking Flat Olive Drab Green paint
Rattle Canned Flat Black hood
Body is straight with no dents or dings (exception: hood isn't the straightest though)
Paint is chipped in a few places (mostly the bumpers and in the jams)
16v Lip Spoiler
FK Mirrors
GLI Spoiler
All flares and sideskirts present
Single Round Grille and Radiator Support (many broken tabs on grille)
H4 Headlights w/194 city lights
Porsche Front Door Handles
All lights and signals function except third brake light which was not present when purchased.
Interior:
Front Mk3 Leathers (no headrests)
Rear Mk2 GTI Leather w/cloth inserts
Canadian Mk3 Non-airbag steering wheel
Manual windows and sunroof
Cracked Red-stripe Dash (non-matching VIN)
HVAC Box: installed a used one that I cleaned, wrapped doors, and resealed with a New Heater core.
Leather shift boot
Hardwood rear deck
MDF Reinforced factory front door speaker pods
Mint Black tweed headliner w/deleted handles
Gray carpet
Car now has ALL interior trim pieces in black
Horn button: dummy switch, ex-defrost switch.
All seat-belts returned to stock.
Stock front window cranks (still have ricey looking ones if desired)
Condition when I acquired the car: no door cards, no third brake light, no rear door handles, mix-matched stock-ish leaking exhaust, extremely worn Mk3 steering wheel, no sound system, leaking gas tank, no functioning gas gauge, odo, or coolant temp gauge, no working turn signals, tag or reverse lights (all painted over w/flat black), no HVAC box, bypassed heater core as it wasn't there, ac compressor still in (yet all other components deleted), interior leaking water, no wipers or washers, no washer reservoir or pump, power steering didn't work and leaked fluid, no rear seat, nasty beat stock front jetta seats, no interior trim and missing most seat belt components, aero frontend (still have and can include), no functioning horn, no functioning rear defrost.
Resolution:
The PO I bought it from had received the car on a trade, removed a few desired parts and passed it on to me in another trade. I nor he really knew why this car was so stripped as it was but I resolved all of these issues, except for the third brake light, rear defrost, and coolant temp gauge. The gas tank had evidence of multiple patches so it was replaced with a good tank from a donor Mk2 Jetta. The car passed North Carolina inspection in May 2009 and I am confident it would pass any state inspection in its current condition. The aero frontend is in good shape, I just had a single round setup sitting around and like the look a bit more.
Rust:
Roof had some surface rust in two small areas, I sanded it out and primered the areas with intent to have the roof re-sprayed.
Passenger floor board has a rust hole about 1" diameter. No other floor rust.
No strut tower rot.
Pics can be found here: http://img529.imageshack.us/g/img0834rr.jpg/
