Author Topic: Vacuum Pump Rebuild Parts Help  (Read 2571 times)
September 08, 2010, 01:31:25 pm
socalsean
  • 25
« on: September 08, 2010, 01:31:25 pm »
Hello all,
   I have this vacuum pump on my 1982 Jetta 1.6 na diesel.
Uploaded with ImageShack.us
Which of these rebuild kits do I need to rebuild this pump? Do I need one of both?
http://www.autohausaz.com/search/product.aspx?sid=nwpa2x55suid2rv4qx1ubke5&makeid=800026@VW&modelid=1282676@JETTA%20DELUXE&year=1982&cid=18@Electrical%20%26%20Vacuum&gid=11818@Vacuum%20Pump%20Repair%20Kit
Thanks in advance!
Reply #1September 08, 2010, 04:07:26 pm
Re: Vacuum Pump Rebuild Parts Help
« Reply #1 on: September 08, 2010, 04:07:26 pm »
You would be further ahead to buy a rotary style vacuum pump off a 85-92 engine. You will need to block off the hole in the plate going to the block.
Sorry I can`t answer your question, I`ve never dealt with one of those pumps before.
Reply #2October 04, 2010, 07:20:30 pm
ldeikis
  • 56
« Reply #2 on: October 04, 2010, 07:20:30 pm »
I believe you need the first one.  The important part is that big round thing, which is the diapgragm that has failed.  I don't know what that other, rectangular thing is, and those second kits don't look like anything I've seen in my pump.   I'd look in my Bentley but it's a mile away in the car, and it's pouring.
Really, though, what BurnYourMoney is suggesting is the way to go.  Look here or on vortex for someone selling a used mkII diesel  vacuum pump, they're cheap because they basically NEVER fail.  I rebuilt my mk1 one (like yours) twice, then upgraded and never looked back.  Yes, it's cheap and easy to rebuild them, but why do it at all if you can score a better used one for just a little more money?
The Mk2 pump just bolts into the same hole the old one came out of.  It doesn't have an output, though, just the "suck" hose from the brake booster and hvac control.  I got a T from the autoparts store and T'd the old output line into the crank breather that runs to the intake.  You could also just plug it.
Luke
81 Rabbit 1.6 N/A
Reply #3October 04, 2010, 08:02:28 pm
Quantum TD
  • 1195
« Reply #3 on: October 04, 2010, 08:02:28 pm »
Luke
The only problem with the MK2 ones is the oil pump keyways wear the hell out. Take a look at yours the next time it's out. I'm sure it's wallered out to all hell.
