1987 jetta diesel 350,000kms
Topic: 1987 jetta diesel 350,000kms (Read 3630 times)
September 01, 2010, 05:46:43 pm
wesley64
Newbie
September 01, 2010, 05:46:43 pm »
i have a 1987 jetta diesel with the auto transmission.recently it has started to take a little longer to shift from second into third.it makes the shift at around 80km/hr,whereas before it would shift at around 50km/hr.there is no slipping,just a late shift.the oil is in perfect shape and at the right level.
any help would be appreciated
brett
September 01, 2010, 07:50:06 pm
Re: 1987 jetta diesel 350,000kms
September 01, 2010, 07:50:06 pm »
First I would verify fluid level, and then I would re-adjust the throttle/tranny cables. If you still have a problem I would look at the brake band adjustment. The specs are in the Bentley.
September 01, 2010, 09:34:23 pm
Dakotakid
September 01, 2010, 09:34:23 pm »
Pull the pan and clean or replace the screen/filter and replace the gasket as well as what Tyler said.
I ran one of these for 435,000 miles by changing the fluid (the pan volume....about 1/2 of capacity) pretty much every 5,000 miles and cleaning the screen and keeping the pan very clean.
At 435K, it was still shifting and running great (except just beginning to need more revs in reverse....barely more revs). The problem was that the engine died and I never re-employed the trans.
September 02, 2010, 08:50:39 am
September 02, 2010, 08:50:39 am »
Worst comes to worse you can rebuild it yourself for around $300 and a weekend.
September 02, 2010, 02:20:37 pm
hooper
Newbie
September 02, 2010, 02:20:37 pm »
i had this problem with my 1.8 carb auto and it was down to some stretching in the cable from the box to the carb..readjusted it and it was much better. not sure on the setup on the diesel though.
on a side note how does the diesel auto drive? is it sluggish? just wondered as i pulled the auto box out of my GL and have since pulled the carb engine out in and put a TD in. ive been asked about diesel auto's and have toyed with the idea (ive still got the auto stuff) but i dont think they did any here in the uk. is it standard on your side of the pond?
September 02, 2010, 02:43:12 pm
September 02, 2010, 02:43:12 pm »
The auto diesels in the mk1 and mk2s are pretty rare, probably less then a 1000:1 ratio to manuals. My mom's has a giles pump on it and it's not fast but it doesn't feel to be lacking for normal day to day driving. It's a 1.6NA. If anything ever were to happen to that tranny I would use a 4 speed auto out of a B3/MK3. It's electronically controlled though so I don't really like that idea. My mom refuses to daily a manual car. She knows how to, but doesn't like it.
September 02, 2010, 08:29:44 pm
bevboyy
September 02, 2010, 08:29:44 pm »
You need to source out the TJ trans from 85-87 gassers...3.12 final is decent on the highway (3120 @ 100kph). Sure beat the EQ that was in my Quantum - 3.76 final..talk about screaming...
The only issue, finding a auto diesel starter..
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
September 02, 2010, 11:04:03 pm
wesley64
Newbie
September 02, 2010, 11:04:03 pm »
is there a free bently manual onine?i have sourced free manuals for my other cars online.
thanks for the info guys.i will try those throttle and band adjustments when i get a manual.
brett
September 05, 2010, 01:18:32 pm
bevboyy
September 05, 2010, 01:18:32 pm »
Yes do a search on Google and you will find in pdf form..
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
